Use install Samsung firmware Flash tool - Odin Download 3.13.1 Latest Version support latest android versions. Also, Odin 3.09 Recommended for Jellybean, KitKat firmware. Odin3 v3.10.7 Recommended Lollipop firmware.
www.odindownload.club
To help you perform a factory reset if your Samsung tablet is working and powered ON, please follow the instructions mentioned below:
- It is recommended to back up all the data like Phone contacts, Email accounts, App settings and Downloaded apps, Music-Picture-Videos, Internet browsing data and Personal data from the tablet before performing factory reset.
- From the Home screen, navigate: Apps > Settings > Privacy.
- Click on 'Factory data reset'.
- Click on 'Reset tablet'.
- Click on 'Erase everything'.
- Allow several minutes for the factory data reset and reboot processes to complete.
Now, if in case you need to perform a factory reset if your Samsung tablet is powered OFF, please follow the instructions mentioned below:
- Press and hold the 'Volume Up button' and then briefly press the 'Power button' to power on the device.
- Release the 'Volume Up button' and the 'Power button' when the Samsung logo displays on the screen.
- Use the 'Volume Up button' to select the 'small android with an arrow' icon.
- Press the 'Volume down button'.
- From the Recovery Console screen, use the 'Volume button' to select 'Wipe Data / Factory Reset' then press the 'Power button'.
- Use the 'Volume button' to select 'Yes' then press the 'Power button'.
- Once the Wipe Data / Factory Reset has completed, use the 'Volume button' to select 'Reboot System Now' then press the 'Power button'.
GuruAid.com
SOURCE: Frozen Galaxy Tablet
Update your firmware by using your sd card... place sd card in compurter...Go to galaxy website download firmware to your sd card then follow direction from website how to start the download on your galaxy.Good luck
SOURCE: Can I reset factory settings on Samsung Galaxy tablet
This hard reset can be done even if the device won't seem to power on.
Great Article, Thanks For Shering Information with
