It's not an easy task. However, you still can unlock iPhone with the help of below instructions.
It is a good habit to have your iPad backed up regularly. In case of your iPad is locked, disabled or being stolen, you can easily recover your data from it. Otherwise, you'll lose all the data. To unlock iPad screen without password or to unlock disabled iPad mean you have to remove your previous pass code and restore your iPad. Here we introduce three methods which you can follow.
Method One: How to unlock iPad without password using iTunes
- 1. Connect iPad to the computer you have synced with.
- 2. Open iTunes on your computer and connect it with your iPad. If fortunate, you can enter the iTunes without password. But in most cases, there would be prompt asking for a pass code. Try another computer you've synced with, or use recovery mode. (The recovery mode will be mentioned in method three.)
- 3. Find your iPad in summary and make a manual backup. Once the backup have finished, click Restore your iPad with the most relevant back-up.
Method Two: How to unlock iPad screen without password with iCloud
You can also use iCloud to remove your password and recover your data if you have backed up before it was locked. And it is in the premise that you have set up Find My iPhone on your iPad, and you did remember your Apple ID, you can use iCloud to unlock your iPad.
- 1. Open your laptop or computer, go to icloud.com/find or open the iCloud app.
- 2. If the sign-in window pops up, just sign in with your Apple ID.
- 3. There's an All Devices button at the top-left of the window, click on it to call out a drop-down menu and choose your iOS device.
- 4. Click Erase (your device) in the prompt to finalize the process.
- 5. Now you can either recovery data to your device from a backup or set up as new if there isn't any back-up before.
For more methods, check:
How to Unlock iPhone
