Model: TDP31001.
SOURCE: Deleting Files
1. Select folder (A/B/C/D)
2. Select file.
3. Press ERASE once and DELETE will
blink on the screen.
4. Press and hold ERASE for 3 seconds
to confirm deleting. (or press STOP to
cancel erasing file)
SOURCE: my digital recorder wont work it says its full but
You will lose your data, but using the FORMAT command while not connected to a computer will restore the default settings and let it work again.
SOURCE: Sony ICD-UX70/UX80 digital recorder...memory full problem
I solved the problem by connecting my Sony IC Recorder to the USB port on my McBook Pro computer and then emptying the trash can on the Mac computer. Visually (flashing red indicator light) and audibly (the recorder's sound that indicates something being erased), it was clear that mp3 files were finally, really being erased on the Sony recorder even though the recorder's own screen display had previously shown only empty folders and no files. Dragging files to the trash can doesn't really erase them unless you also empty the trash. All dragging to the trash can does is somehow mark the files in a way that, unfortunately, makes them invisible to Sony's file detection system.
Chuck in Omaha
SOURCE: Olympus ds-30 deleted file recovery
First things first: DO NOT take any more videos or audio with the recorder that you want to recover files from in case you may quite possibly ruin your chances of voice memo file recovery.
Then connect your device to a PC, and have a try of Photo Recovery (also recover audio, voice memos, video files etc), a data recovery program which is good at recovering media files lost. If you are Mac OS X users, turn to Data Recovery for Mac.
Lastly, I hope you good luck. Again you should remember - the more you use your recorder, the less likely you may be able to recover the deleted files back! So STOP using the device ASAP. Regards
SOURCE: Need to recover deleted file from recorder
Sorry for a late reply but chances are high to recover your deleted files.
