I'm having a lifegear treadmill 97520 when i switch it on it's keeping give beeb sound and showing on the screen Er 02 what is the problem and how can i fix it
Try below:
ERROR CODE
DESCRIPTION
E1
Speed error (The treadmill running speed is 3.2 kph faster than the displayed
speed). The treadmill will stop immediately when the console detects this error.
E2
Speed error (The treadmill running speed is 3.2 kph slower than the displayed
speed). The treadmill will stop 16 seconds later after the console detects this
error.
Troubleshooting / Resetting error codes
In the rare event of the treadmill displaying an error code ("E" followed by a number), simply reset
the computer by:
1. Step off the treadmill. Ensure that you are clear of the running belt.
2. Turn the treadmill off at the master power switch located near the motor housing.
WARNING: Ensure nothing is positioned near or under running belt which may possibly block
it's normal operation.
3. Turn the treadmill on at the master power switch.
4. Ensure that the Safety Tether Key is securely and properly installed onto the console or just
reinstalling the Safety Tether Key can also reset the display.
If the above does not clear the error code, please contact the nearest Dealer/Service Center
LifeGear 97320 Owner Manual Page 17
SOURCE: belt slipping
Here are two solutions one is to get the belt centered on the treadmill
and the other is to tighten the belt.
There should be two bolts
in the rear of the treadmill, one on each
side. These bolts adjust the rear roller of the treadmill. The walking
belt will always go to the side that is looser. To get the belt back
on track, (if you can start the treadmill so the belt is running)
tighten the bolt on the side that the belt has slipped to. Tighten the
bolt a little bit at a time. If you tighten the bolt too much, then the
belt will go to the other side.
To tighten the belt, start by
locating the two bolts that adjust the
rear roller (one on each side of the unit in the back). Run the unit at
about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that
what you do to one side, you MUST do to the other side or the belt will
get off center. After you tighten it 1/4 turn, check the belt to see if
it is still slipping. If it is then tighten the belt 1/4 turn again.
Continue until the belt does not slip, but do not tighten the bolts more
than 2 full turns.
SOURCE: lifegear motion plus 97920 problem
please adjust the REED switch and see the diagram attached. Test for open or faulty. Clean it + tight the connector very well.
2) if you equipment has battery replalce by new ones and clean it, and putt with FULL energy.
3) TIGHT THE RIBBON CABLE for keypads , clean it and try again.
God bless you
