didaya simwaka Posted on May 22, 2016
My Sony dav-dz150k home theater is displaying push power protect.I checked the the sound output,the speaker wires for shorting but are fine
farhad hamzeh
Level 1:
Habit-Forming:
New Friend:
  • Contributor 3 Answers
  • Posted on May 22, 2016
farhad hamzeh
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
Questions
0
Helped
699
Points
16
Hi.please check on your device control panel if you have power control key push it ,if not please see behind the device it may be there
3 Related Answers
The witch
Francisco Mauricio G
  • 1551 Answers
  • Posted on Jun 24, 2010
SOURCE: push power protector showing up in sony dvd home theater system
Always be the audio amplifier IC damaged
Anonymous
  • 635 Answers
  • Posted on Aug 11, 2011
SOURCE: Have a SONY DAV DZ370
Push power protect is an indication of an output failure ( Amplifier ). The Home theater system is asking you to switch off the power to prevent further damage. This mode is called protection mode and you will need professional help sort it out.
Anonymous
  • Posted on Aug 27, 2012
SOURCE: Need replacement speaker cables for dav-hdx576wf
Since noone else gave you a good answer I will. I lost some cables to mine a while ago and found this awesome jerry rig solution; Go to radio shack, and ask for '14-16 gauge star ring terminal connectors' Should come in a pack of 10 and be about 2$. On the back of the unit where these connectors fit, there should be two prongs. You will need two star-rings for each connector slot. Wire up your connectors and crimp the ends LIGHTLY with a pair of pliers. The star-ring connector connected to the negative wire should be inserted to the left prong, (left if you are facing the back of the unit), and the right prong is the positive. If you did everything correctly, you should be able to make your own wires for sony stereo systems whenever you need to. Saved my ***, hope it did the same for you. Here is a link to what they look like. http://www.shopping.com/radio-shack-non-insulated-crimp-on-star-ring-terminals-10-pack/info
2answers
I have a Sony DAVDZ150K home theater system. It displays DEST error. What is remedy please.
Not sure. General advice is 1) Try cold start (unplug, let set for several minutes, replug and try) 2) Try a reset (page 72 of user manual) 3) check any cabling. The troubleshooting in the user manual does not refer to this specific error.
https://www.manualslib.com/manual/948580/Sony-Dav-Dz150k.html?page=81#manual
1helpful
How to fix push power protector Sony DAV-DZ870W
try disconnecting all speaker wires from the main unit, then turn it on. If it still goes into protect - then the amp is blown and you need to replace the main board.
Display shows "push power protection"-DVD home theater system
there is a short in the amp that needs to be repaired before the unit will operate correctly.
MY SONY HBD-DZ810 HOME THEATER IS CONSTANTLY SHOWING PUSH POWER PROTECTOR
The "PROTECT" and "PUSH POWER" messages will flash alternately when the protective device of the amplifier has been activated because a strong signal was input, or if there is a short-circuit detected. Press the POWER button on the unit to turn off the system, and check the following items after "STANDBY" disappears.
1) Are the + and - speaker cords short-circuited?
2) Are you using only the specified speakers?.
3) Is anything blocking the ventilation holes of the system?
You may also refer to the following link for additional troubleshooting steps.
PROTECT and PUSH POWER flash alternately on the amplifier screen
2helpful
Hi, whenever i am trying to power ON my hifi...i'm getting a message error on the display screen ''PUSH POWER PROTECT'...flashing continuously. please can anyone advise what should I...
This indicates that you have a blown output amplifier or shorted speaker wire. Disconnect all the speaker wires and try to turn it on once more. If it shows the same display give it to a service
Push Power Protector?
This indicates that you have a blown output amplifier or shorted speaker wire. Disconnect all the speaker wires and try to turn it on once more. If it shows the same display give it to a service center for repair.
1helpful
2answers
Getting an error display as "Push power protector" in my Sony Home theatre - DAV DZ777. what is the solution.
Turn off your unit at the power button. Check speaker outputs for a short circuit - also check other end of speaker cables for a short. If you can't find an obvious problem then disconnect all speakers and power up the unit. If all is OK then connect speakers one at a time (this should be done with the unit powered OFF) and power up after each conection. This should identify which output is causing the problem.
If that does not work then it's an internal fault that will require a service engineer to identify - but I hope that is not the case!
Just purchased the Sony DAV-HDX285 and hooked everything up correctly. The only thing I added more speaker wire. When I turned the system on the Protector light Push Power came on. I returned the system...
Protection is usually a speaker wire shorted somewhere. Does that suggest something? Did the two units function okay BEFORE you modified them? Or afte ryou disconenct the speakers?
17helpful
3answers
"Push Power'' and ''Protector"
my sony bravia is KLV-32S400A. i tried to stop the dvd playing and turn off the home theatre, but the tv is still on. suddenly there was a loud blast sound and the home theatre shows PUSH POWER PROTECTOR.
please help what should i do with it?
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
