Simplest is to use the LR button at the bottom of the channel strips you want to send to the main mix. Make sure you set the gain for each channel in use so that the clip light just occasionally blinked then back off a fraction.
If you want to use sub channels assign the strip to the appropriate one 1/2 or 3/4 and the assign the sub to the main mix and bring the subs up.
SOURCE: hooking up powerd monitors to a Mackie 1604 VLZ3
Are you sending the main mix to the monitors or are you giving them their own mix? What about using the sub groups, use 1 for your monitor send.
