Apple company sent me a message on my Apple iPad. Asking me to down load on there messenger on Apple inc. well I already have a messenger on my Apple iPad from or u can say with a Facebook,, So what would u won't me to do. Please Answer my question, Thank u.
SOURCE: Apple Ipad won't charge
IThe iPad needs more power than the average USB device. It doesn't run and charge at the same time on a regular USB port. If it doesn't charge with the original charger though, you have a hardware issue. You can always take it to the apple store and demonstrate the problem there, you'll probably receive a replacement. If you have issues with the warranty, there are third party places that will find our what's wrong. If you want to do it yourself, the good news is, it's not too hard to open it. Here is an iPad Repair Guide that shows how to open an iPad. If you want somebody else to do it for you go to iPad Repair NYC.
SOURCE: Bouncing balls won't load on. Facebook
Call Zynga's Phone#: 800-762-2530
How to reach a live person: Dial 3 when recording begins
Here's the best information I have found about it. Please calm down and be patient. There are people here with much more urgent problems than your app-addiction. Have fun, anyway!
http://www.crushingcandies.com/candy-crush-saga-level-29
The battery in it has most likely expired and may cost more than a new iPad to replace. A voltmeter across the charger or a friends iPad may be useful to test your charger works ok.
SOURCE: re set ipad mini
Generally speaking, you need the Apple ID to reset your iPad. iPad needs you to enter the Apple ID to switch off your account and the Find My iPhone service will be turn off. If you are using iTunes to reset your iPad, you need to enter the Apple ID when your iPad reboots.
But if you have no Apple ID or passcode, you will have to reset your iPad without Apple ID. To reset iPad without Apple ID, you need first put iPad into DFU mode and connect it to your iTunes. Your iTunes will help you to reset your iPad without entering Apple ID easily. Resetting your iPad with this method will result in wiping all the data in your iPad. The following steps will show you how to do that.
Step 1: Open iTunes on your computer and connect your iPad to the computer with a USB cable.
Step 2: After that, turn off you device. Press and hold the Home button for 3 seconds.
Step 3: Put your iPad into DFU mode: Press and hold the Power and Home button for 10 seconds. Then release the power button and keep holding the home button. When you see the Apple logo disappears, you have successfully put your iPad into DFU mode.
Step 4: When iTunes detects that your iPad is in recovery mode, you can restore it now.
Step 5: Click on Restore iPad. Then you will be notified after the reset and your iPad will take a restart.
After resetting your iPad with the guidance mentioned above, you'd better create a new Apple ID and password in time. After resetting iPad, you will get all the data swept from iPad, and you can restore the files from your iPad, iTunes backup or iCloud backup. However, you can't backup iPad to iTunes/iCloud without Apple ID before you reset your iPad. In this case, you need the third-party iOS data recovery software to help you recover lost data from iPad after factory reset without Apple ID.
http://www.leawo.org/tutorial/how-to-reset-iphone-without-apple-id.html
