I have labeled all my folders. My drive was full. I eliminated stuff. only to find the names on my folders replaced by red underlines. I need my names on my folders
SOURCE: open folders disappear off side or topof desktop
Possible solution: Click "System Preferences" in the Apple menu in the upper left-hand corner of the screen. Click "Expose' & Spaces". It was called "Dashboard and Expose'" in previous OS versions.
Look at the Expose' section. If you see anything about a mouse button next to "Show Desktop", click on it and change it to "-" (dash). I'm guessing this feature is mapped to one of your mouse buttons, such as the middle button. Clear that, and you won't be triggering it accidentally.
Hope that makes sense.
Bot
Testimonial: "Excellent assistance , solved the problem, TKS"
SOURCE: My Document Folder has disappear from Dock.....I
You should be able to drag the Documents folder from a Finder window to the Dock.
Open a Finder window (click on the desktop, then hit Command-N). On the left side, go to the Places item (click the arrow on the left to expand it). Select your user name. In the window, you should see all the folders in your home folder. Click and drag the Documents folder down to the right side of the Dock -- to the right of the dotted line, before the Trash.
If you hover over the other folder icons, you should be able to move the pointer in between them. Once they split apart to open up a space for you, release the mouse button.
You cannot drag the little icon on the left of the Finder window (under your user ID) to the Dock. It has to be the regular folder icon on the right side of the Finder window.
I found it, from another web site. SmartUSB.net.
It explains step by step, how to change
font color in a flash drive.
Change font color in your flash drive
http://www.smartusb.net/p/change-font-color-of-your-flash-drive.html
Show your colors to your brother.
Change your flash
drive icon
http://www.smartusb.net/p/change-flash-drive-icon.html
Insert symbols to your flash drive label
http://www.smartusb.net/p/insert-symbols-to-flash-drive-label.html
Hide a file or folder in your flash drive
http://www.smartusb.net/p/hide-file-or-folder-in-flash-drive.html
Add wallpaper to your flash drive background
http://www.smartusb.net/p/add-wallpaper-to-flash-drive-background.html
