2006 GMC Sierra Logo
Posted on Jul 17, 2009
Tailgate latch will not lock when closed - 2006 GMC Sierra
Anonymous
Level 1:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Sep 12, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
9
Questions
0
Helped
2629
Points
12
There are two Possibilites with this issue ... Either the latches are bound or rusted and can be lubricated with lithium grease after cleaning or the plastic retaining clips may have broken inside your tailgate. To locate these, remove the three bolts holding in the latch assembly and inspect the clips attached to the two control rods that will latch/release your tailgate. I have found spraying white litium grease every three months into the latches of my tailgate has eliminated the same problem on my truck.
5 Related Answers
Anonymous
  • 107 Answers
  • Posted on Feb 19, 2009
SOURCE: Latch won't lock when closing tailgate 2004 Silverado
most likely a broken spring inside latch
Vitally Alcher
  • 1645 Answers
  • Posted on Sep 14, 2009
SOURCE: Tailgate won't latch shut
Lubricate all the components with silicone graphite spray can and keep actuating all levers.
Watch for any obstacles and deformity in latch , strike, ruber seals.
Vitally
Anonymous
  • 12 Answers
  • Posted on Oct 10, 2009
SOURCE: tailgate latch on my 2002 silverado is stuck in closed postion
Remove the molding ring from around the handle. Becareful not to break the taps that lock it in. After removing the molding you should see the handle mechanism. There is a rod coming in from each side (each one runs out the the actual latch). Make sure each rod is connected into the handle assembly. If it is not put the rod into the hole and find the retainer clip to keep it in place.
Anonymous
  • 1509 Answers
  • Posted on May 09, 2011
SOURCE: GMC Envoy 2004 XUV tailgate
Two things happen. One the latch is already latched and therefore it's closed before the gate shut, When you try to close it you might notice that the door don't close all the way. This doe'snt have to be thwe case. the other thing that happens if the lock mechanism is working, You here it click? The latch is stuck as the opener is stuck. You might get lucky and spray the latch with Blaster or other rust buster type penatrant. Theres angles though the opening of the latch . Spray on several angles and repleatly close the door trying to vibrate the Penatrant into the stuck area. Looking at the latch use a screw driver to move the latch and see if you can cycle it though it's positions to see if you can latch and unlatch it with the tool and reopen by pullung the handle ( you may need to try ther inside handle too and even the remote openner if you have one. Ussaaaly you need to push the button twice to open the rear hatch so it may take a few trys and spraying to get it to come loose.. Some vehicals stay closed a long time and stuck is the way to think.. But if the door is used often the linkage inside the door mayh have come off the the latch is closed and the linkage doesn't open the laTCH AND THE THING MANAGED TO GET CLOSED WITHT THE DOOR OPEN.
Anonymous
  • Posted on May 31, 2011
SOURCE: Tailgate/trunk latch will not engage so the
Tailgate/trunk latch will not engage so the tailgate just bounces won't close - is there something I can do to fix this on my own?
The tailgate on my 2003 Volvo XC90 wont close because the locking mechanism closed while the tailgate was open and is obstructed from closing around the post. I have tried locking and unlocking the doors...
Once you take the whole tailgate apart, you may find the current latch mechanism is only jammed, and with some lubrication and/or bending or adjustment, it may still work.
However, it may need replacement to fix the problem.
God bless your efforts.
Tailgate door wont latch
IT sounds like you closed the Trunk/ Liftgate with the Latch partway closed. Lube the Latch and hopefully it is not bent. If it is not latching, you can try and ensure it is aligned propery (use a piece of Tape and see where it is hitting the STRIKER...
If not, you are going to be replacing the Latching Mechanism.
2helpful
2answers
Tailgate open/ lock latch in closed position so tailgate will not close/ can't et lock latch to open so I can close tailgate completely
Annoying, but easy to fix: Actuate the opening handle and manually rotate the latch to the open position.
2009 Ford F350 tailgate latch stuck in the open position, tailgate won't latch closed.
I am not quite sure, but on the sides of the tailgate, where it locks, can't you push the mechanism back? I think you can. It either turns them from latch to open. You can try this. See if you can push it into lock mode.
6helpful
2answers
Tailgate latch on my 2002 silverado is stuck in closed postion
1helpful
Rear tailgate indicator light stays on even though tailgate is closed tight. with this light staying on the doors will not lock. Is there a sensor in the tailgate door that might be obstructed.
take the panel off the tailgate and check ur tailgate latch and or switch. may need replacement . be sure not to slam the tailgate down too hard anything, could damage the latch
3helpful
1helpful
Tailgate door won't close
does this van have a button to open the back door? if it does push just like you are opening it and it should unlock itself
Repare electric window tailgate 1990 fullsise blazer
latch the locks and trick the door in thinking it is shut. then once you are done pull the handle and relase the latches before you close the door.
there is a safty switch in the latches that keep the window from working unless the door is shut.
Top GMC Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a GMC Expert? Answer questions, earn points and help others
