Details: I had a heating element recently replaced. Since the repair, I don't seem to have as much hot water available. I checked the wiring and some of the terminals seemed to be lose. I tightened them. However, it appears the thermostat is for a dual element w/h. I checked the apcom schematic and it does show that it can be done with this unit. Any help would be helpful. Product(s) H10-A water heater with a apcom 07863 thermostat. Question Can a single element water heater be controlled with a multi-element thermostat? Chris
As far as not having as much hot water as before, check the label on the side of the water heater and see what the element wattage is supposed to be. Then take the door off the element cover and look at (don't touch!) the element and see if it is the right one. Also check to see that the voltage matches up (ie: they didn't put a 110 volt element in a 240 volt water heater.)
