SOURCE: transfer my video from panasonic sdr - h40
try to use USB to plug your device to your computer. make sure that you have an installed driver for your camcorder to recognize your device on your pc. all brand new camcorder came with an installation software cd. now your ready to transfer your video to your computer. use any movie maker application like ulead movie maker, nero movie maker or windows movie maker edit it and save it. burn it to your vcd or dvd burner to play on your dvd player. if you dont have a driver i will find one for you. hope that helps!
CHARCOIS
SOURCE: Need Panasonic SDR-H40 software download
You can connect to any computer with a USB port. It appears as a hard drive after you tell the camera to connect (in the menu). Then just copy the .mod files to a spot on yor computer; there will be one for each movie clip.
Your next chore is changing them into MPEG files at the correct aspect ratio. If you shot in 16:9 they will be squished together unless you use the SDCopy freeware utility to set the widescreen flag. It also renames and downloads files for you, and it's small. There's a link from this tutorial page, which also explains a lot about aspect ratios and such:
http://www.elurauser.com/articles/JVC_Everio_mod_files.jsp
SOURCE: Hi am wanting to put some footage from panasonic
Your Panasonic camera has a USB port on it as associated by the accompanying cable that plugs into it and has a USB end on the other cable. Note that if your videos are on the SD card, you can take it out and put in your computer via a SD adaptor to USB. The hard drive files though are a little more tricky... you have to have the camera being fed by the AC adaptor instead of the battery.. (it looks like the battery and plugs into its hole on the bottom with a cable hangiong out that plugs into the battery charger.. You will not be able to transfer the files unless you have this power configuration.. this is to keep the transfer from being disrupted by running out of battery power. The files are MOD files which are MPEG2 files just renemed. You can rename them to MPG instead of MOD once you copy to the computer. The USB connection forces the PC to make a drive letter for the hard drive in the camera. I hope that helps out
Than ks!
STan Skaggs
