Tools & Hardware - Others Logo
Brian Riddle Posted on May 15, 2016
How do I take the plunge base off my dewalt 618
The cord receptacle on my Dewalt 618 router cracked. I received the replacement part, but now I have to disconnect the old receptacle from the wires. How do I do this?
Undo the main housing to access the connections. Note each screw's placement as some may be smaller than others.
Apr 20, 2019 • Dryers
Looking for DeWalt DW625 router manual
Make a quich search on google. I found several links where you can download the manual.
Rhf 618 static all the time on the radio, s 7 on the meter all the time.
I HAVE THE SAME PROB WITH ALL THE STATIC , %50 OF THE MEETER MOST OF THE TIME, HARD TO HERE EVEN LOAD STATIONS, CAN ANY ONE EXPLAIN , IT IS ONLY ON THE 618 , NOT MY PRESIDENT ,,
1helpful
I am looking for a manual for the DW621 plunge router. These solutions aren't helping me .
Here's a link to where DeWalt has the manual for this. You will also have to identify if you have type 1, 2 or 3. This didn't work for me using the Google Chrome browser, I had to use Internet Explorer. Good luck
2helpful
The blade won't retract properly, making the saw unsafe
Usually the guard sticks due to dirt ... clean the entire mechanism and lub with a dry lubricant (graphite or similar) Check for screws that may be too loose or to tight.
You are right, this saw is dangerous ... dont use it until you have it repaired (by you or the DeWalt Service Center near you).
Thanks for your interest in FixYa.com
I just received a 693 plunge router via internet order. As soon as i took out the plunge part out of the case and moved the lever it pupped up and now will not move up or down > Is there something I am...
The plunge base is spring loaded. When you move the lever is springs to the up position. To lower it place the base on a flat surface, press and hold the lever down and push down on the handles. The router bit height should be set on the depth rod with the base in the down position. Then release it to the up position. When you have positioned the bit where you want it on the work piece, press the lever and "plunge" the bit down into the workpiece. The depth rod setting will stop the bit at the depth you set it for.
Dewalt dw615 how do you secure the plunge is it the black knobs, thanks ged
Yes, it is the black handles / knobs.
Rotate them clockwise to lock the plunge, anti-clockwise to unlock.
Hope this helps,
Matt
The plunge lock "slips" when the router is used in a table
You can try to adjust the lever that moves the plunge and see if that helps, but a plunge router isn't made for upside use. If you have the option and use the router upside down often, you may want to get a fixed base.
Top Dewalt Tools & Hardware - Others Experts
john h
Sean Wright
Sean Wright
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
