Where is the fuel filter located
SOURCE: fuel filter/pump
To my knowledge, both are integrated in a single unit together with the fuel level sending unit, the float and a return motor. They are in a coffee-can sized assembly inside the fuel tank removal from the top. The big job is bringing the fuel tank down.
A temporary workaround on stuck pump is to bang on the bottom of the fuel tank with the ignition switch ON.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
SOURCE: Where is the Fuel Filter located on 1988 Dodge Ram 50
Under hood, center, lower engine area, between fuel pump and carburetor, mounted in fuel line
SOURCE: unable to locate the fuel filter on my 2005 dodge magnum 2.7 liter
It's located in your fuel tank.
cheers.
SOURCE: Fuel filter location 1999 dodge durango
the fuel filter is located on the iner driver or pasenger side frame railing inbetween the front and rear doors. yes it has filter in the tank which is more comely know as the sock or straner. the filter will look like a metal canister .
SOURCE: Where is the filter located on a 2001 dodge ram
2001 Dodge Truck RAM 2500 3/4
ton 4WD 5.9L Turbo Diesel 6cyl the Fuel Filter is located under hood, passenger side, lower engine area,
mounted above starter.
ton 4WD 5.9L SFI 8cyl the Fuel Filter is located under vehicle, center, below seating area, mounted on
top of fuel tank, in fuel pump module.
Hope helps with this (remember rated the help).
If I'm not mistaken the filter is part if the fuel pump assy on these vehicles. Should be able to access the pump from under the rear seat, should be an access panel there
