SOURCE: Formula required
On sheet 4, select cell A1 and press "=" (don't press enter key).
Select the sheet 1 tab and click on the cell at the top left corner of your sheet 1 data. (dont press enter yet.) Press the "+" sign and then click on the Sheet 2 tab. Select the cell on sheet 2 at the top left corner of the data table on that sheet. Now press "+" again. Now select the sheet 3 tab and select the top left corner of the table there. Finally, press the enter key and you will be back on sheet 4. Cell A1 on sheet 4 will show the sum of the first cells of the tables on sheets 1-3.
Here's how to copy the formula on sheet 4/A1 to the other cells:
Select cells A1:A12 on sheet 4. (in other words, highlight all the cells that will become the top row of the table on sheet 4.) Now press Ctrl-R. This will copy the formula in cell A1 to all the highlighted cells to the Right of it. Finally, highlight the area that will become your table on sheet 4 (12 colums, 10 rows). Press Ctrl-d. This will copy the formulas in the first row Down to all the cells in the highlighted area below.
SOURCE: SUMIF formula
One in general should not use Find & Replace.
I would recommend always creating the first formula manually by selecting the cells. This will avoid common errors like extra spaces.
SOURCE: Need to use the VLOOKUP formula for more then one column
You probably need to organise your pricelist sheet so that you only have 2 columns, product and price. If this doesn't fix you, please provide the syntax of your vlookup code.
SOURCE: show the sum of the cells that matches with a given output
If the cell with the sum in it was created by a formula then you could use the formula to find out which cells were selected when creating it. for instance...
the sum of cells A1 - A9 would look like =sum(A1:A9)
for more information check out:
http://www.contextures.com/xlFunctions01.html
SOURCE: merge two excel sheets with same columns with sum.
Please give some data for sample to solve your query..
Sunil Charate
9763710696
