Olympus DS-2300 Digital Voice Recorder Logo
O
Oneeka Hill Posted on May 12, 2016
It's saying memory error, then it goes to format, but it won't allow me to choose anything. I don't want to format. I'm trying to listen to a recording I have on there. What can I do?
3 Related Answers
Anonymous
  • 9 Answers
  • Posted on Aug 20, 2008
SOURCE: Memory card error
first borrow a card from a friend and try a different card. if it still doesn't work... trow it away. It's not worth fixing. you can take off the backing and expose the card slot. The card slot is designed so you can see all the connections where there are little holes in the card retainer assembly. you can check to see if they are corroded. I don't care to explain how to pull the backing off again. look at some of the other questions about this cammera. But start by prying the bottom and dont hinge the top back to far nor pull the top away from the cammera with a lot of force. you'll see why. And watch the capacitor. Even with no batteries in the cammera.... it still bites!!!
Anonymous
  • 9 Answers
  • Posted on Jun 11, 2009
SOURCE: i have just bought a new memory card for my
you need at least a 4 gb for it to read.. i just did mine too.. they are on sale right now at Target for $ 14.99, try this and let me know if this helped you good luk. tiffany in chattanooga tennessee
caroldon
  • 17130 Answers
  • Posted on Sep 21, 2010
SOURCE: My olympus 8010 will not
Remove your card and place it in the carrd reader of your PC. Now try to format and clean off the files. If it is not detected clean contacts and try if not the card can be defective.
2answers
SD Card Problems with Vivitar Vivicam 5118!
What size is the memory card. If it's larger than 4GB then it won't work in the 5118.
Try using another card. Don't format it in your computer but do format it in the camera before trying to take pictures.
4helpful
2answers
Camera says out of memory won't let me take pictures. i cleared all the pictures out and still cant take pictures. What do you think the problem is?
I'm assuming you are trying to use an SD card in your camera and not the internal memory. I suggest you format the memory card if you are sure there is nothing on the card. Formatting the memory card deletes everything on the card and sets it up with a file system that your camera recognizes. Follow these steps to format your memory card using your camera. 1. Turn camera off 2. Insert memory card 3. Turn camera on 4. When the memory card is inserted in the camera, the [Format card] option appears in the setup menu 5. Choose Format to format the entire card. Don't choose Quick Format 6. Wait until your card is formatted
After formatting your memory card, try turning your camera off and on and you should now be able to take pictures to your memory card.
P.S. If you remove your memory card you can choose Format Memory from the setup menu to format the camera's built-in internal memory
4helpful
I try to download stuff off the internet but it keeps saying connect storage media at the save destination what does this mean
File formats that the PS3 doesn't recognize as something that it can play can only be saved to a USB storage device, or a memory card. You can't download anything to the PS3 hard drive via the browser that you couldn't copy to it from a USB storage device. That is what the error message means. You have to connect an external storage device, because the PS3 won't store this file format on the internal drive. This protects the integrity of the system. If you connect a USB drive or memory card (you will need a USB adapter for the memory card if you don't have a launch PS3), then you can download anything that you want using the PS3 web browser.
1helpful
When i try to download something it says connect storage media to save destination what does that mean and what can i do to download stuff without that coming up
File formats that the PS3 doesn't recognize as something that it can play, can only be saved to a USB storage device, or a memory card. You can't download anything to the PS3 hard drive via the browser that you couldn't copy to it from a USB storage device. That is what the error message means. You have to connect an external storage device, because the PS3 won't store this file format on the internal drive. This protects the integrity of the system. If you connect a USB drive or memory card (you will need a USB adapter for the memory card if you don't have a launch PS3), then you can download anything that you want using the PS3 web browser. Sometimes called a thumb drive, a USB drive costs about $20 and plugs into the USB slot and is removable.
Was OK, but now memory card requires formatting? Kodak Easy Share C-530. I tried several times to put in new memory card, but it always says it needs reformatting and when i try "continue" it then goes to:...
She is not arguing with the camera. Sheesh. When she says she hits "continue" she is talking about continue for the camera to format the card. But instead of formating the card it says filesystem error e00100. The camera will NOT format the card. I have the same problem. I can format the card on the computer, but again the camera says it can not read the card and needs to format. You choose to format, and it says filesystem error e00100. My card is brand new. So I used cards I have owned for while and used in other cameras. Same thing happens. I tried 4 different cards. A 4gb SDHC, thought that format was not compatible so switched to a regular SD 2gb. Same thing happened. Also tried Standard SD 16mb & 128 mb. All do the same thing.
1helpful
2answers
I have just bought a new memory card for my Olympus D 390 camera, when i put the card in the camera it goes to a screen saying card set up, then gives the options of power off or Foemat. When i choose...
1helpful
Memory card reader
Try format the card using FAT (not FAT32 or NTFS).
Sony CyberShot DSC W50 internal memory error
Before anything else try to reset all from the menu for the internal settings. This may get the camera back to where you will see the format option.
Make sure you format and delete all that is in the internal memory. This may be due to a full or corrupted memory space internally.
Because the camera can work with the memory stick, it seems that there is some problem with the memory internal space.
Try the format as mentioned above. Some cameras will only allow you to delete all in the internal memory.
Go to the menu and look for format the memory, and remove the card so that the internal memory will be defaulted.
Formatting Memory Card
did you format your card? try going into the set-up menu on your camera and you should find a format option - THIS WILL ERASE ANYTHING YOU MAY HAVE HAD ON THE CARD...so if you have anything on there use a memory card reader and transfer it to your computer before formatting. If the formatting doesn't fix the card error message you could try formatting it on your computer (if you have a pc, go to 'my computer' and under 'removable devices' you should see the memory card, right click and choose format - i don't know the process for macs, but i would guess do a ctrl+click on the memory card when it appears on the desktop). If that still doesn't work the card is probably corrupt and you may need a new one.
49helpful
7answers
Top Olympus Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Ngoro
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
