SOURCE: Warming Plate
actually the warming plate have heating element... they stop working only when the heating element gets open circuited or wire to that plate gets cut....
SOURCE: bunn omatic model F20 doesn't stop dripping
Check out:
http://whles.com/General%20Mtx%20Knowledge%20%20Tony%20Roach/BunnOMatic%20F35%20F20%20F15%20x.pdf
This is the free full service manual F15, F20 & F35 complete with troubleshooting section at the rear. This section has easy, plain english steps to follow to solve this very problem (others, too).
SOURCE: Bunn Coffee maker leaks
Hi, you can go to www.bunnomatic.com, and select for home or commercial units, and get an 800 number to call for service and parts. If they cannot help you a appliance repair shop should be able to get you going, thank you.
SOURCE: BUNN Pour-Omatic
Most likely it is your tank heater, but look on the top of the tank heater, because sometimes the wire will burn off the top of the element
SOURCE: Bunn (Pour Omatic) coffee maker
When a machine leaks, it is generally an indication of a bad seal or gasket. If you will call Customer Service at 800-352-2866 with the model and date code we will be happy to help you resolve your issue.
