Sometimes these things get seized up and are impossible to remove. If it isn't completely strupped you can soaked it in wd40 and if that doesn't work try using a torch to heat it. If it is stripped since you are replacing the wheel anyway see if you can cut out some louvers and try to drill it out. If the doesn't work in worst case scenarios I have had to cut the shaft of motor with saw zall and replace motor. I know it's expensive and works so I would cut the wheel however you have to and carefully drill set screw out.
Thanks Caleb, i believe the blower wheel is removable, because i can find the part in ebay, just wondering how to do it
SOURCE: power outage Blodgett Conveyor Oven
On the back of the motors there are safty overload reset's, these are small red push in buttons. Also there are fuses for each motor inside the control panels assembly.
SOURCE: athens controls inc board for old blodgett oven (gas)
Athena still sells this product as a ttc001
call me at 610-729-1032
SOURCE: CANT FIND PART FOR COMMERCIAL PIZZA OVEN
contact first choice with mod no and ser no and they will source your part.first choice is in staffordshire,catering suppliers.
