NEC Dterm DTP 16D-1 Corded Phone Logo
Kala Burns Posted on May 06, 2016
My phone is stuck on park and will not let me answer it or go away
Volkswagen Tiguan. The handbrake is stuck. MY TIGUAN WALSWAGEN HANDLE BRAKE STUCK
The brake is electronic. It is a known issue
The parking brake is stuck on my 2011 VW Tiguan AWD
JustAnswer
https://www.justanswer.com > vw-volkswagen > irflj-p...
Feb 17, 2022 - Press the footbrake for 35 seconds, then whilst continuing to press the footbrake, press the EPB button in for 10 seconds, start the car, (still ...
1 answer · Top answer: Hello and welcome to just answer my name is ***** ***** am I assisting please Sorry to hear ...
Reset parking brake that won't disengage - DIY
VW Vortex
https://www.vwvortex.com > ... > Tiguan (PQ35)
Nov 23, 2020 - The solution, offered by the dealership service department, is to: (a) remove key from ignition; (b) remove both battery cables from their respective terminals ...
SAFETY TIP: Beware the Tiguan Electronic Parking Brake!
Jul 15, 2011
HELP: How to override the electronic parking brake?
Jan 13, 2016
Parking brake is not releasing as it should - VW Vortex
Nov 27, 2020
emergency brake stuck on! ' VW Vortex - Volkswagen Forum
Nov 23, 2020
More results from www.vwvortex.com
2answers
2013 Volkswagen Jetta SE shifter frozen in R but will roll like neutral. I cannot start car or release shifter?
They usually stick in Park!
shifter gets stuck in reverse...
VW Vortex https://www.vwvortex.com > ... > Corrado
Jul 29, 2002 - Re: shifter gets stuck in reverse... ( i bet the small c clip type of thing fell off. it goes to the left of the pivot on the shift lever.
stuck in reverse...what the hell is going on? - VW Vortex
Jul 18, 2011
CAR WON'T START! Thinks it's in Reverse but it's in park ...
May 29, 2004
Manual transmission stuck in reverse ' VW Vortex
Feb 13, 2017
Transmission stuck in gear ' VW Vortex - Volkswagen Forum
Jul 6, 2016
It's stuck in reverse. Won't go into park or neutral to
JustAnswer https://www.justanswer.com > vw-volkswagen > 9wq...
Sep 11, 2016 - Won't go into park or neutral to start. It's been doing this for a while...not shifting into - Answered by a verified VW Mechanic.
1 answer · Top answer: When you step on the brake pedal, does the indicator show the shifter is rele
https://www.google.com/search?q=2013+Volkswagen+Jetta+SE+shifter+frozen+in+R
Locked the keys inside.
Slim jim works all the time. This may sound nuts, but I proved it to work. If someone has a second key fob and a cell phone, have them click the unlock button several times really close to the phone. You get real close to the antenna and watch the doors unlock. This , of course works when you're stuck in a parking lot and the other key fob is miles away.
Frequently will not shift out of park - I usually have to turn the engine off several times and suddenly it will go into gear - what is going on?
Ford Escape Questions - shifter stuck in park - CarGurus
www.cargurus.com > Questions > Ford > Escape
CarGurusFeb 2, 2015 - shifter stuck in park - Sometimes my shifter is hard to get out of park. what would cause this, and how would I fix it?
Ford Escape Questions - SHIFTER - CarGurus
CarGurusOct 28, 2011 - 1 out of 1 people think this is helpful. ... 2011 FORD ESCAPE WILL NOT GO IN TO GEAR DEALER SAID COFFE SPILLED IN IT . ... shifter stuck in park 13 answers ... Other times (and it's getting more often), I have to push and push (and keep pushing) the gear shifter ... 2012 Ford Escape XLT For Sale.
'01 Escape Stuck in Park; safety interlock - Ford Truck ...
www.ford-trucks.com > ... > Escape & Escape Hybrid
2answers
I have a car stuck in park, i found a small sping in shift case can it be replace or do i have to buy another shifter or could it be the ingition park cable lock:
The parking paul or rod needs a return spring to retract it away from the parking drum.After you select the ranges !
Call Park Issues..
Well to place a call on Park:
-> you should answer the call -or- be on a call
-> press FEATURE 7 4
-> then look at the display as it will give you a park number
Anyone can pick up a phone now, then dial that park number which you've seen - to answer the call.
To Transfer:
-> press FEATURE 7 0
-> then dial the extension you want to transfer to...
Now you can either stay on the line to tell the person who you are transferring and then hang up the phone -or- just hang up after dialling the extension to complete the transfer.
Can't get the car out of park. have pressed on the brake but still stuck in park
the same thing happen to me you have to take the plastic shifter knob off the plastic pice inside broke i bet
I have a 2003 Kia and mine did this same thing. They replaced some switch in the brake and gear shifter. It hasn't had a problem since.
4helpful
2answers
Xk8 stuck in park
sound like your brake switch or the fuse.
you have to step on the brake to take it out of park and if it doesnt see that the brake is being pressed it wont unlock the shifter
later paul
Top NEC Lands Phones Experts
ADMIN Andrew
ADMIN Andrew
Don A
Don A
RAJA NADEEM AKHTER
RAJA NADEEM AKHTER
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
