Porplemontage - Admin/Bureaucrat - I LOADED THE LAUNDRY ON A 1998 SCHINDLER WM00555773 (89 PERSONS/39 KG) AND I PRESS THE DOOR CLOSE BUTTON TO CLOSE THE DOOR. THEN, FE ERROR COME UP. THE FE MEANS THE WATER OVERFILLS DUE TO FAULTY VALVE. TOO BAD! I JUST SWITCH IT OFF AND CALL THE LG ELECTRONICS CENTRE, BUT IT DID NOT. THE WATER TEMPERATURE IS 20 AND THE SPIN SPEED INTENSITY IS 1200. EXPLAIN OR ANSWER WHY I HAVE THE FE ERROR ON THE WASHER? SO I SHOULD HAVE REPLACED BY 2016 LG LATER.
SOURCE: the water overfills due to the faulty water valve
May be the valve or level indicator. close valves and check screens with washer at the end of the hose. Clean with a tooth brush and soapy water. Run a load with 1/2 cup vinegar. If the valve needs replaced install an R.V. filter to prevent this in the future. It screws inline from the valve to the hose and for $20 and 10 minuets it is a good investment. Your clothes will also be cleaner.
it sounds like either your pump is not working or the line is clogged. probably the pump though.
