My battery backup ups system Cyber Powre 625avr went dead on just one row, the battery backup side and yet the surge protector outlets row works fine. This unit is out of warranty. What should I do?
Thanks for your assistance,
Vicki
The battery you need is BP7-12. I called Cyberpower and they emailed me the info. It is easy to put in. Batteryplex.com has them for about $29. That includes shipping. There is no tax unless you live in FL.
Hello Vicki,
What you are describing is usually a result of the batteries losing their ability to hold a charge.
The surge protector side does not rely on the batteries.
I found good batteries at a reasonable cost on ebay, but I think you're going to need to replace batteries at this point.
Hope this helps.
Charlie
The batteries used by Cyberpower are BB battery brand. This model uses the BP7-12, which is used in a lot of UPS brands. There are six screws on the bottom of the unit that are tucked inside of holes. Remove those and the top will come off revealing the batteries. It's really quite simple. Here's a link to that BP7-12: http://www.batteryinternational.com/cyber-power-cps625avr-ups-battery-ups-batteries-f1.html
Also have same problem...just happened!
What kind of batteries and how do you replace them?
Jon
The battery inside is a standard alarm battery, 12 volt that can be found easyly. In fact, any 12 volt rechargable battery will work. I used an old car battery and it's working good for a year now...
I've tried the reset button to no avail.
I am experiencing the same problem - the battery backup side is not working but the other side is. Also, the power on light will not come on, even though it is plugged into the wall and the red button is in the "on" position.
I checked eBay for batteries but searching for 625AVR batteries pulled up nothing. What type of replacement batteries should I be searching for?
I am having the same issue but the power light blinks. Which type/style of batteries are good for replacement I wonder
My CyberPower 625AVR is 5 years old and just stopped working. I've read the posts about replacing the batteries, but see no way to open the unit and replace them? Thanks....
