WILL NOT START, BLOWING GAS OUT OF MUFFLER,SPARK PLUG IS GETTING GOOD FIRE
Hi..in general i always set the high and low screws at 2 turns out from a complete stop..and please dont tighten the screws too tight..it will bend the needles...I think it will..or should run at them settings...as far as the gas out of the engine..it is or has a problem with the carb...did you remove the carb...? Also try starting it with only starting fluid for a very short time..this is how I check to see if all else is ok..spray it in the carb in take...
