How do i repair the touch screen digitizer on the LG VU CU920? I have the replacement but I'm not sure what to do. However, there are residues covered in those cube like things on the top left corner of phone. I don't know that they are called but those are the things that connects to the touch screen digitizer in order for it to work. Should I clean it and will it still work if there are still some residues from the glue which belongs to the old touch screen digitizer? What kind of glue should I use? THANK YOU IN ADVANCE!
SOURCE: LG Vu CU920
i think you type the code in 0000 (zeroes) and there ya go. [: i went to att.com and typed in puk code and then it said type in 0000 so, hope that helped!
SOURCE: unlock code for lg vu cu920
Nope.
Try first calling the manufacturer to get the subsidy code.
If you do not want to call the manufacturer , then try the method on link below, but it does not work on all cu920:
Subsidy unlock instructions for the cu920
SOURCE: Security code for my LG Vu cu920
You can either try 1234...or the last 4 digets of your cell phone number.
SOURCE: My LG VU CU920 touch screen will not respond i
Are you able to get to the screen calibration (<Settings><System><Screen>? If so, try to recalibrate. If not, are you still under warranty? Contact ATT, and see if they will replace the unit.
