SOURCE: invalid format
the comp is set to an unsupported screen res. set it to 640x480 and try again.
SOURCE: PS3 (Pal) won't connect to Sylvania HD TV
I just figured it out last night - if you have used your playstation on an hd tv previously, it is set at the highest resolution possible - 1080p. You need to take it back to that tv, and go to display settings on your tv. If you select HDMI as they type of connection you'd like to make, it asks you what resolution your tv supports. In your tv instruction guide, it should give you this information. Check mark all of the resolutions your tv supports, making sure not to confuse 1080i and 1080p. After doing this you can take it back to your other television and it should work.
Use the power button on the front of the console, to put it in standby mode (red light on).
Then press and hold the power button until you hear two beeps.
This should fixya.... :)
please rate this answer!....
Testimonial: "thankyou, that actually worked, i did not know this could be fixed this way"
SOURCE: my tv says invalid format
Your PS3 is sending a 1080P signal to a TV that can only handle 720P or 1080i. Connect the PS3 using the A/V cables, fix the resolution and then go back to HDMI.
SOURCE: My LC320SLX Sylvania TV displays the message
You are getting that message becuase the MAC video resolution is too high for the TV handle, you need to lower your MAC video resolution to the native resolution of the TV, read your manual to find out what it is.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
