Live View doesnt allow operation of 2 sec delayed shutter. How do I fix please?
By cancelling Live View I can achieve the delayed shutter. Alternatively I can shoot with Live View but without a delay ie then risk camera shake. Should be able to shoot Live and delayed.
Re: Live View doesnt allow operation of 2 sec delayed...
You use Live view to get an accurate focus then turn live view off and then once 2 sec delay has been selected (this can be done before going into Live View) release the shutter.
In Live View mode, evaluative metering is always used to determine correct exposure, though exposure compensation is available. The Exposure Simulation function will attempt to recreate the exposure level that would be obtained with your current settings on the LCD display. This may raise noise levels of the live view feed beyond what could be expected in the final image, since it must operate with a fast enough shutter speed to achieve its required refresh rate. The aperture also remains open by default, and so the exposure simulation doesn't indicate the areas in focus unless you configure the Set button to provide depth-of-field preview, and then hold it down during live view. Exposure Simulation will attempt to continue even with depth of field preview active, though this may raise the live view noise levels even further. If you pass outside the range where the live view feed can simulate your exposure, the "Exp. Sim" icon near the bottom right of the LCD will blink, as a warning.
When you depress the shutter button halfway, you are (in fact) activating the focus mechanism.
If in AF mode, you should hear the 'beep' when focus is achieved.
However, bear in mind that the XSi has three focussing modes: Quick mode, Live View, and Manual. There is a difference in how focussing is achieved between the Quick and Live View modes. (see page 102 onwards of the user manual "using AF to focus").
Also, the barrel of the lens will move during the focus operation.
If this does not happen, then there is a definate problem.
Having images in focus despite having no movement on the lens, simply means that the aperture settings are probably small enough to give sufficient depth of field to include your subject.
The camera shoots continuously while the shutter button is held down.
there are three options for it
Continuous(Approx. 4.0 img/sec)
Shooting AF (Approx. 1.1 img per secnd)
Shooting LV (1.2 images per secnd) (Live View)
Press teh shutter button. Use up and down buttons to select the shooting modes. The camera will continue to reord continous images as long as the shutter button is held down. The taking will cease when it is released.
Set the camera in TV mode, (delayed shutter mode) set the shutter at 15 sec, click to take a picture and during that 15 secs (like, after 7 seconds) open the battery compartment which cuts contact with the battery circuit. Close the battery cover. At this point the camera works fine ... but only temporarily.... Here is the key to the permanent fix. While the camera is working via the temporary fix, take many, many pictures. Hundreds! I probably snapped 400-600 pics. The idea is to wear down the little patches of hardened oil on the shutter blades. For the next three days I took hundreds of pics each day. Basically, I just aimed the camera at the wall or whatever and snapped off several hundred pics.
Press the 4-way switch downwards to cycle through the selftimer modes: First press shows the selftimer symbol, which means 10 secs delay, next press shows selftimer2 symbol, which gives 2 secs delay. When delay is set, press the shutter button to take the picture. The selftimer lamp will blink untill the picture is taken.
Your cam is perfect. when youuse it from my computer> view my cam> u see faster. But when you on your cam in messenger there is 1 or 2 sec delay. Its happend by internet speed. But as per your information 1 - 2 sec delay is a good result of your web cam . Just enjoy it.
Some people face 3-4 sec delay. all of these depend on internet upload speed.
Thanks & waiting for your feedback
you have to enable the live view from the menu. then press the set button on the center of the arrow keys.
when shooting with the live view on, auto focus will not work if you press the shutter button halfway, you should press the button marked '*' to make the auto focus work. the small rectangle on the lcd monitor will turn green when correct focus is achieved.
1. Press the Func/Set button
2. On the left side of the LCD, scroll down to Drive Mode icon (usually a square, third item down)
3. Use right arrow key to select clockface with 2 (2 sec delay) or 10 (10 sec delay)
4. Press the Func/Set button
Now whenever you press the shutter button, the camera will delay 2 or 10 seconds before a picture is taken. Use the same steps to go back to normal (square icon) drive mode.
The longest part of the shutter delay is caused by the autofocus mechanism.
Most cameras will let you press the button half-way down and wait until the autofocus is locked. Then wait for the action to occur. When you press the button the remaining distance, there will be a shutter delay of about 0.2 seconds before the picture is taken.
Using that technique will let you capture action shots.
There is no way to improve shutter delay on any particular camera.
The newer digital cameras are showing improvement in this area. Some are achieving autofocus lock in 0.4 seconds and shutter delay of an additional 0.1 seconds.
