Water dispensor is not working, ice dispensor is work fine
Every so often the water dispensor stops working, we do a little leveling and it works. This time I can't get it to work. The ice dispensor is working fine. Help in TEXAS
How do i check the water line for the water dispenser to see if it is clogged. the ice maker works fine.How do i check the water line for the water dispenser to see if it is clogged. the ice maker works fine.
Our water dispenser stopped working. The Ice maker works fine. We narrowed down where the problem was. The water line keeps freezing. My freezer is set low, like 3 out of 9 being the coldest. I dont know what to do to keep the water working and not freezing.Our water dispenser stopped working. The Ice maker works fine. We narrowed down where the problem was. The water line keeps freezing. My freezer is set low, like 3 out of 9 being the coldest. I dont know what to do to keep the water working and not freezing.
AnonymousDec 27, 2007
Same problem...no water even after filter change, ice is fine. Seems to be alot of pressure when I removed old filter. RichSame problem...no water even after filter change, ice is fine. Seems to be alot of pressure when I removed old filter. Rich
You can't post conmments that contain an email address.
Re: water dispensor is not working, ice dispensor is work...
It depends on where it is freezing. Can you determine where the freezing is? These things don't usually clog. They can develop what is called a vapor lock in the water dispenser behind the meat drawer in the refer. For freezing let me know where it is freezing.
HI MIKE.may be its just jammed with ice.empty all and try empty first.might be making ice and solidifying due to water leak.(high pressure or valve) or motor gone.good luck Ali
A lot of filters ( not all ) do not even access the ice maker . Only the water dispensor . If your water dispensor is working fine , then you need to replace the dual water inlet valve behind the refrig . This is the piece the wall water line connects to . It is called a dual valve because there are 2 coils on the valve . 1 for the ice maker and 1 for the water dispensor .
you have prime the system air out of the water lines this is easy to do
put a glass big enough to cover water dispensor outlet cause its going to project water out at you press and hold button till water starts to run smooth
these fridges will spit water at you when you prime the system at first cause theres air blockage in lines
Since you have water getting to the icemaker/dispenser, the most common problem I've seen is the solenoid valve is history and needs replacing. It could also be the switch that is normally activated by the dispenser itself and in turn activates the solenoid valve or the wiring in-between the switch and valve, but I have personally not seen either one of those go bad.
Same problem need solution
