I have not dropped my camera. I just took a picture...it worked. But the lens is now stuck out. The viewing screen is blank. Will not turn on. I replaced main batteries and the little battery. Still will not turn on, though I get a brief flicker of light...my lens is still stuck out.
The same thing happened with my camera! The lens is stuck out, everytime i turn it on i get a flicker of the light, and the screen says E18.The same thing happened with my camera! The lens is stuck out, everytime i turn it on i get a flicker of the light, and the screen says E18.
You can't post conmments that contain an email address.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Is it just the live view from the lens that you can't see ( totally blank screen), or are the icons visible?
If it still shows the icons but no live view then I suspect the shutter mechanism is stuck over the lens inside the camera.
Have a look at the lens and see if you can see the inner lens? You may have to adjust the zoom to bring the inner lens up to the end of the lens barrel.
If it is stuck then it will require removing and inspecting / cleaning.
Do the icons show up on the screen or is it totally blank?
Can you view previous pictures?
If the icons show on the screen then have a look into the lens to see if the shutter is closed over the inner lens. you may have to adjust the zoom to bring the inner lens and shutter mechanism up close to the outer lens to get a better look.
If the shutter is covering the inner lens then it is stuck and will need to be freed by opening the camera up.
If the screen is just black then it just may be possible that the ribbon for the screen has partially slipped out of it's socket on the main board.
If it comes out all the way then the camera should not even power up.
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
The lens maybe out of track. Perhaps you have bumped the camera or dropped it. Look if the lens are a bit tilted, if so, try straighten the lens with your fingers, very gently. Hope it works.
I have a Kodak 1275. Green light would go on the off and lens was stuck open. Now for solution that worked for me. Get a can of compressed air, like what you use for computer keyboards. Blow the compressed air all around your stuck open lens, not to fast and switch directions of where you blow air around stuck opened lens. Make sure batteries are fresh and fully charged. Tap your camera against the palm of your hand twice, not to hard or you may damage instead of jarring lens lose. Next lay your camera on a table lens facing up, push power button on so camera will try to auto focus and lens should reseat itself and lens should move freely. It doesn`t have to look dirty or dusty, little tiny particles can cause the lens to get stuck and shut off fast because it is a safety feature. If this does not work try plugging your camera into computer so the lcd screen does not try to go on , thus giving even more power to get your lens moving . Do not try to force it closed by pushing or twisting with your hand or you may cause damage that will cost as much as the camera to fix.
There are 3 pins in the camera lens that slide in grooves allowing it to move you have knocked out 1 or more.
only an experienced tech can attempt fix , camera must be totally disassembled.
