See some articles below for similar errors.
It does not appear to be user fixable error unless it is that debris to be cleaned. Printer HP Laser Jet CP4525 59 F0 Printer Error
SOURCE: Driver of HP Laserjet CP 1215 Printer needed for MAC machine
HP does not currently have software or driver downloads available for your product for that operating system.
So we and you can't do anything to run this printer on your Mac Laptop.
I hope this help you lot.
Please rate the solution.
Scott
SOURCE: My Printer HP 1600 Laserjet error 10.1001
Did you fix your problem? I have the same one. With Hp 2600N
All cartridge are new, and i removed the orange tab from each one.
I even tryed a second new cyan.
Did you remove All the orange tab from cartridge?
SOURCE: hp printer cp 2025 erorr code 58.04
This error code indicates "Low voltage power supply error"
SOURCE: problem in hp cp 2025 color laser printer that
This error typically indicates that the cartridge was moved (e.g. previously installed) from another printer to your printer. The error should not affect your ability to print. If you want to clear the error, replace the affected cartridge with a genuine HP replacement.
SOURCE: clening/mismatch printing for hp clj cp-2025
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
