Good Afternoon Larz, thank you for your post!
From the information you have provided the cooktop and oven on your Frigidaire range, FFEF3017ZW, are not working. This could be an internal issue with your control panel, a wiring harness, or the terminal black. Since it could be an issue with the electrical component, I would suggest having a professional technician out for a proper diagnosis. This will help you to avoid any unnecessary part purchases or improper disassembly of the range. I hope this information is helpful. -Matt
SOURCE: Frigidaire Electric Range ES200/300
there is sometimes a thermal fuse inside the caseing might have to take the top off if not then you will need a new timer be safe and unplug
SOURCE: MY HOTPOINT SELF CLEANING STOVE
how do I get my self cleaning to come on in my hotpoint stove
SOURCE: Frigidaire ES400 oven controls
Contacts are fused. Get a new one, cut the power and replace it.
SOURCE: Frigidaire Gallery ES340 electric range, burners will not turn on
Okay,
1, check your power, locate your breaker for the range. turn the breaker off and turn it back on.
Your Range it is electronic control on the Oven but not the Stove Top heating elements.
After you reset the breaker and it still not work.
Please let me know more about the unit.
When you purchase.
How/when it happen.
What is the indicator showing.
[email protected]
SOURCE: Frigidaire ES200/300 316257123
look for a shorted bake element .. you should be able to see where it poped. ( some times ) if you have ohm meter you can ck for an open element . **** //
If
your electric oven is taking too long to heat or just not heating up
right, then check out this tip that will give more detail about your
problem.
Oven
Problems Electric Oven is Heating Slowly or Poorly
heatman101
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
If
problem.
Oven
heatman101
