Question about Samsung Washing Machines
I have a error code 5e on my washing machine samsung frount loader and have followed all instruction but the machine error still occurs stops about 15 min into wash with this code
  • Samsung Master
  • 5,638 Answers
Restore Deleted Files on Samsung
The Android data recovery
could be best helper to recover deleted files on Samsung thoroughly. It is a professional data recovery tool good at restoring deleted data from Android device. A various types of Android data are supported, for instance, contacts, text messages, photos, videos, call logs, WhatsApp messages, apps data and more. It could be used to perform Android data recovery for any data loss causes.
More importantly, this program have other function, which are Android data backup & restore, recover data from broken Android. It is compatible with almost all models of Samsung and other Android models, including Galaxy S9/S8/S7/S6/S5, Note 9/8/5/4.
LEARN MORE
Posted on Nov 07, 2019
  • Samsung Master
  • 1,692 Answers
Hi Nikki, Is it 5e OR e5.... The link below is a samsung washing machine error code list, I hope this helps............CHEERS..
Samsung Washing Machine Error Fault Codes
Posted on Apr 28, 2016
We have moved house and plumbed in our machine and code 5E has come up Any ideas what is going wrong and how to fix it
The '5E' Error is displayed when the water is not draining properly from the Washing Machine. If the water does not drain in 15 minutes, a buzzer will sound , and the remaining time indicator will show '5E' Error. You can perform following steps to resolve the issue : Clean the debris filter.
Jul 13, 2017 | Samsung Washing Machines
5e error code
Samsung Washing Machine cleaning the pump & coin trap ...
? 5:11
www.youtube.com/watch?v=OofFb280Cn4
Jan 15, 2012 - Uploaded by whichwasher2007 Samsung Washing Machine cleaning the pump & coin trap .....you could try installing a new pump to avoid the 5E error, fixing the pump will ...
Sep 19, 2015 | Washing Machines
I have a Samsung front loader. It has been stopping with the error code 5E (filter problem ) for a few months now. Turning the machine off then on again after 20min gets it going again. The fault always...
The 5E error mean:
Pump won’t empty - not draining
As usual with these error codes for not draining the first thing to do is check the pump filter but, on Samsung washing machines, the drain pump itself is often faulty. You can find how to fix this problem on youtube, just text it "Samsung washing machine 5E error".
May 16, 2017 | Samsung WF520ABP - 5.0 cu. ft. Steam...
Hi i have a 5.0 kg. samsung SW5OUSP washing machine as i turned it on it stopped in rinsing cycle and the message says 5E
5E. Water Drain Error.
5E is displayed if the water level frequency detected os 25KHz or less in the initial phase of the UNB - detecting cycle. The WATER DRAIN ERROR
can be rectified by turning the POWER SW OFF AND THEN BACK on.
Hope this helps you
Feb 01, 2012 | Samsung Washing Machines
7kg 1045 front loader, says SE or 5E wont drain, will open fill and wash but not draining
Hello & Welcome to FixYa
5E is a water drain error and occurs when the water level frequency does not show changes. First clean the debris filter located at the bottom of the washer and then turn the unit back on after 15 minutes. Please get back to me if you have any other questions.
Kevin
Apr 17, 2011 | Samsung Washing Machines
De error code on samsung topo loader stops working
0E - OVER-FLOW ERROR
Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER switch OFF. Water is drained prior to POWER switch OFF. The tub is drained for 2 minutes if a frequency of more than 25 KHz is detected.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 28, 2010 | Samsung SW62ASP Top Load Washer
Getting error 5e WF7708 samsung front loader. Have cleaned all filters nothing appears to be blocked. But it will not finish a cycle.
A 5E code means that the drain pump is iether clogged, with lint, impeller damage, drain hose clogged, or a loose connection on the pump connectors
Jan 06, 2010 | Samsung Washing Machines
Error Caode 5E - Machine not spinning
Can you get me the model number? Thank You!
Jun 19, 2009 | Samsung Washing Machines
Washing Machines Logo
2,047 people viewed this question
Top Samsung Washing Machines Experts
Eric Rotmil
Eric Rotmil
Jerry Greenberg
Jerry Greenberg
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
