Husqvarna hu725 22" 190cc walk behind mower
Hi Andrew:
It is quite possible that the blade is bent or the metal "grass discharge guide" has been damaged.
If you have a pickup truck handy and you can put the mower facing outward on the tailgate, this procedure is easier.
- remove the spark plug lead to ensure that the mower cannot accidentally start.
- Push the handle down so that the mower is tilted back and the underside of the cutting deck is exposed.
- slowly rotate the blade and see where it contacts (or has been contacting any metal parts.
- remove and replace the blade if it has been bent. (They can be straightened but it is not recommended)
- Use 2 hammers (one as a "dolly") to straighten or repair any bent sheet metal.
- Replace the plug lead and go cut grass.
Cheers
