The control board lights up so I have power, but the belt does not move. I do not hear the motor at all. ALso the incline decline does not engage. I can move the belt manually when it is off or on.
If you wish to get some details; check the site linked here. Pull up older posts...
http://electro-medical.blogspot.com/
SOURCE: Nordictrack motor will not run when start button is pushed.
Likely the cover of one of the motor brushes popped off. Unplug the machine before you pop it back in place, then try it again.
If that doesn't work, most likely it's the motor control board, or possibly the console, or finally just a loose connection behind the console.
But most likely, it's the motor brush cover. I've been seeing that alot with this model.
SOURCE: NordicTrack T5.3 belt stopped working. It's only 1
HI, its seems like the belt on the motor has either slipped off, or you just need to tighten it. best way to find out is to take off the front pannel showing the motor. then stand on the treadmill. start it and you will see the problem.
SOURCE: Nordic Track A2250 Pro stuck inclined
My Nordic Track Treadmill A2250 is stuck on the 12% incline position and it wont go back down and I have tried to reset it by turning it off, switching the reset button to off and then on or even unplugging it several times. What would be my next move?
You need to call Icon ASAP and get a tech out under warranty to fix the issue.
Testimonial: "Very helpful. Thank you "
