Lands Phones Logo
J
Jerry Winslett Posted on Apr 26, 2016
How do i program my headset (corded) for use with my phone?
Mike
Level 1:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Contributor 16 Answers
  • Posted on Apr 26, 2016
Mike
Contributor
Level 1:
New Friend:
Night Owl:
Answers
16
Questions
0
Helped
11537
Points
41
Put earbuds in your ear plug the other end into your phone use the volume button on your phone or on your earbuds play music or answer the phone using your earbuds
Cannot connect headset to the base. The set is mute.
Program a headset button on one of the flexible buttons
1) press program
2) press button to program
3) dial 67
4) press enter or store button
5) press program to end
How do you program phone for headset mode on sts phone and where do you plug it in?
Some phones have jack on the side of the phone. If it does not, you will need a standard telephone headset with amplifier. You will need a handset button (634) programmed on the phone. Then in programing Flash 50 button 4 you will need to disable speakerphone. Flash 50 button 18 determines the headset type: 0-is amplified unit plugged into handset cord, 1-is 2.5mm jack on side of phone,
To use handset, press handset button so it is lit, use on off to answer calls with the handset.
1helpful
Headset on DTU 8D-2 corded phone
If you are using the headset jack on the phone, a headset key needs to be programmed on the the phone. You can do this in program mode and make a line key a headset key. Otherwise you must connect it through the handset. ldtsnj.com
2helpful
2answers
NEC DTerm80 phone
I have the 8 button phone and if you hook up your headset the right way you just have to press the line/feature access key all the way to the right instead of picking up the receiver. Keep the headset on all the time and just press that button to answer or hang up the calls. It works great! ( I have the Dterm80 telephone)
Headset
Do you have a headset button programmed on your phone?
DTU 16D-2 Corded Phone
headset key has to be programmed on a key for it to work properly
I need to program a HeadSet Button
For the DTU phone on an NEC Elite system:
Memory Block 4-12
put in the port number and the Lkey of the extension you want to make a headset key.
Programmin on a 16button phone, Lkey 11 needs to be lit and will display H SET to verify.
For the DTP phone, it is generally on an NEC 2000, which is entirely different.
Top Lands Phones Experts
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
