Press the "Power" button on the TV you want to sync with the universal remote. Push and hold the "LED" button on the remote until the button lights up and stays lit. Push the "TV" button The "LED" light will blink once, then stay lit again. Point the remote toward your TV and press the "Power" button on your remote, holding it down until the TV turns off. Do not press "Power" again after the device turns off. Press the "Enter" button on your remote. The LED light will no longer stay lit. Your remote control is now programmed for use with the device.
The first step in troubleshooting too much resistance or constant resistance begins with the lower board. You will want to first verify that the Field LED is lit on the lower board. As shown in the video, the Field LED is off initially, when the steps are engaged it lights up, after about 5 seconds the light should go off. If the Field LED stays lit during a workout or after a workout is completed, this is a sign that the console is faulty. There is constant power being supplied through the console keeping a full load and causing no change in resistance. If the Field LED remains lit, the console needs replaced.
The Fisher & Paykel Smart Drive and EcoSmart electronic washing machines are equipped with fault detecting software to help easily determine the cause whenever a problem occurs. Not like other electronic washing machines, these ones do not have displays to flash the code, but rather use the eight (8) light-emitting diodes (LED) of the Wash Progress indicators to indicate the fault code. The eight (8) LEDs stands as an 8-bit binary number (zeroes and ones) that must be decoded and then converted to the decimal number system to get the fault code.
The fault code can be decoded by determining which Wash Progress LEDs are lit. Once determined which of the LEDs are lit, write down the 8-bit binary code; 1 for lit LEDs and 0 for the off ones. For example; the final wash, rinse, and spin LEDs are lit; the binary code is 00001101. This in turn can be converted to the decimal number system by multiplying each digit with its corresponding place value then adding up the result. From left to right, the place values are 128, 64, 32, 16, 8, 4 , 2, and 1 respectively. Therefore, the decimal equivalent of 00001101 is 128(0) + 64(0) + 32(0) + 16(0) + 8(1) + 4(1) + 2(0) + 1(1) = 8 + 4 + 1 = 13; the fault code is 13.
Note that incoming traffic will cause the WAN (or Internet) light to blink even if it is 'probe' traffic trying to break in to your network. Such traffic is to be expected and is the reason you have firewall functionality in your gateway router.
On the inside, there is a bit of traffic on any LAN when the computers are turned on. Messages generated by the router itself are used to find computers and printers for a lot of different legitimate reasons.
please LUBE the deck belt+rollers bearing. see the video attached. If the problem persist TIME to replace the old deck belt board. This happen because the lack of maintenance schedule in LUBE. God bless you
note:forget it the LEDS troubleshooting, you must see the functions ONLY when there are electronic problem with the electronic board+sensor
Many errors are first indicated by the illumination of the system-error light in the operator information panel on the front of the server. One or more lights inside the server might also be lit that can direct you to the source of the error. The system information LED lights to alert you that there might be important information recorded in the system-error log. 2. Removing the left-side cover and look at the light panel. These LEDs indicate the type of error that has occurred.3. Once you know the general type of error and the general location of the component involved, the next step is to check the system service label on the outside of the server. This label gives an overview of internal components that correspond to many of the LEDs on the light path diagnostics panel and can help to view lit LEDs inside the server. Note: Some of the LEDs on the light path diagnostics panel will not have a corresponding LED lit on the system board.
IM not sure but on the main menu of the ps3 go to settings then to accesorries settings then go to reassign controllers then if its on another number than 1 put it to 1
How is your router connected? If you have all port lights lit, either green or orange, and nothing connects seeing the Internet, are your problems with wireless access? Is the Wireless set correctly, by going to http://192.168.1.1 and logging in to the router? Make sure the SSID (network name) and other security measures are set correctly ... I prefer WPA-PSK[TKIP] for its simplicity. You will need the passcode you choose to log in with wireless devices.
actually if u repair an aoc monitor alone without getting connected to cpu once u switch on the monitor all led's will lit on ( green light ) it will remain on situation until u connect the vga connector to cpu that's the time led's will lit off and only the power led will remain in green condition.some aoc 5en once u power on power led is in green condition and if not connected to cpu it will be in orange condition.hope u get some idea but i am not sure if it will work with ur monitor. but as long as LEDs lit on i think no problem with ur monitor.
