can you hear a quite louder noise when trying to make water flow?
If no or very faint noise can be heard, pump is probably faulty or needs to be disassembled and cleaned (see tutos on the Net)
If you can hear a loud noise, the pump is working but unable to suck water, keep on trying, if still unsuccessfull you will have to open the machine and fill yourself the watel inlet tube to "help" the pump priming.
Hope that thelps
M
SOURCE: I have a Saeco Incanto
Do you have a filter in your water tank?
if you have a filter, remove it and try.
SOURCE: Saeco via venezia coffee machine wont prime
Turn machine on and make sure that the knob is fully opened, if the pump does not engage(vibrate) then either the machine is not getting power or there is a problem with the pump.
SOURCE: leaking coffee grounds and water
HI
There should be a small amount of coffee residue and about an oz. of water going into the drip tray. This is the pressure relief process, when the machine finishes the coffee making. If it didn't release the pressure thhis way you could have an explosion of coffee when it cycles back.
SOURCE: Am unable to prime water pump
Water is not being drawn from reservoir into boiler. The valve at the base of the boiler seems to function properly. After repeated attempts, I am unable to prime pump and fill boiler with water.
This tells me that either the grind is too fine and or the brew unit screen, and discharge tube needs to be cleaned. Try this first press the button for making a espresso using the manual function, do not add coffee through the door then press the brew button. If water flows freely then the grind is too fine, if you get the water prime error then the screen under the red o-ring on the brew unit needs to be cleaned.
