SOURCE: panasonic kx-t7730
Hello, if you are using this phone with a 308 or 824 system, while the handset is still on the cradle / hook press PROGRAM and then the one touch button you want to assign a CO line to. Now press 0 followed by the line port number ( example 1 ). Press AUTO DIAL / STORE to save the changes. Press PROGRAM to exit program mode.
PLEASE vote if this was helpful
SOURCE: how to set the clock at a panasonic kx-t7730
Basically, there are 2 ways of programming the date
and time - the short way and the long way.
If you are using the KX-T7730 phone on a Panasonic
KX-Txx 308/824 system:
SHORT WAY:
From the Switcboard / Main telephone
( ext 101, 10 or 9 ) with the handset on the
cradle/hook:
1. Press PROGRAM 0
2. Enter Date and Time
( The format is: yymmdd,
1 to 7 1=Monday 2=Tuesday etc, hh:mm,
0 or 1 0=AM 1=PM ) see example
3. Press AUTO DIAL / STORE to save your changes
4. Press PROGRAM to exit program mode
EXAMPLE:
If the date and time is 3 February 2010 Tuesday 2:15 pm you will enter as follows:
100203 2 02:15 1
LONG WAY:
From the Switcboard / Main telephone ( ext 101, 10 or 9 ) with the handset on the cradle/hook:
1. Press PROGRAM * # followed by the system
password ( default is 1234).
2. Now press 000 and then SP-PHONE.
Enter the year.
3. Scroll to the month with the right scroll key
(located at the right bottom corner of the phone).
To change the month use the AUTO ANS / MUTE
button.
4. Now scroll right again and change the date and
day.
To change the day, again use AUTO ANS / MUTE
5. Scroll right again and the time will appear.
Set the time.
To change am/pm scroll to it, and again,
use the AUTO ANS / MUTE button.
6. Press PROGRAM to exit program mode and you
are done.
SOURCE: How do I change the time on a KX-T7730 phone?
SHORT WAY:
cradle/hook:
1. Press PROGRAM 0
EXAMPLE:
100203 2 02:15 1
LONG WAY:
From the Switcboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle/hook:
Enter the year.
button.
day.
Set the time.
are done.
SOURCE: I have Panasonic KX-T7730 model. When I am
If that "continuous sound" matches your hold music, then, without picking up the handset, press "1"
Carl
Testimonial: "Thanks buddy....."
SOURCE: How do I record or change a recorded message on
A Panasonic 7730 phone operates on 18 different Panasonic Key Systems. There are 5 or so different ways to record a message...which one is yours?
The 7730 was first delivered with the TA-824 system. It has the ability for announcements via DISA, which was built in to the USA versions of the TA. It's recorded or changed via the master phone and PROGRAM 911.
A Panasonic TVA or TVS voice mail system does auto attendant functions. It can have both company greetings and custom service messages. Those are changed via mailbox 998, the message manager's box.
Last, the newer system also have "bulit-in" voice mail boxes. Those greetings are recorded by 722xx commands.
Carl
