You didn't say what type & kind of phone you have (iphone or android) or phone service you have (they all do them slightly different). If you dial your own phone number into your cell phone, that should access your voice mail. I have a Sprint Android, so
Press 3 for Personal Options
Press 2 for Greetings
Press 1 to Change Greeting
Press 1 to Record personal greeting or press 2 to select the standard greeting
Depending on your wireless service provider, the method for changing your voice mail greeting or voice mail password might differ. You should be able to access the options for changing your voice mail greeting or voice mail password when you check your voice mail. For more information, contact your wireless service provider.
From the Supervisor menu you can record greetings for all boxes. Check & listen to messages for all boxes. Change options & password for all boxes.
To Access Supervisor Options:
-Access your voicemail box
-From main menu, press 6 for Supervisor Menu
At this point, voice mail will walk you through changing what ever you need to change or check. **See the Supervisor Guide for more detailed information & instructions**
Press and hold the "1" key to call into your AT&T voice mail.
Enter the default passcode (your seven-digit telephone number--not including the area code) using your keypad.
Press "4" to access the "Personal Options" menu. Press "2" to enter the "Administrative" menu, and then press "1" to change your passcode. Enter the default passcode, and then enter your desired passcode. Listen to the playback for verification.
Wait until you are returned to the main menu. Press "4" for "Personal Options," and then press "3" to change your greeting.
5
Press "1" to change your "No Answer/Busy" greeting, or press "2" to change your "Extended Absence" greeting. Follow the voice prompts to record your personal greeting (this replaces the standard "answering machine" recording).
to change the main greeting you need to get into admin programing F983 your also going to need a 7310 or 7324 or a T7316. You have to use the buttons under the LCD screen to navigate after getting into admin press AA
Press GRTG
Press GRTG again
and usually 1 is set for day
and 2 is set for night
press 1 then ok
Press REC.
Hope this helps
1~ you need to know the VM huntgroup number ie; number dialled to access the voicemail system
2~ the administrator mailbox number usually, 999 or 9999 by default
3~ the admin vm pin code which is usually 8642 by default
basic menu selection;
4 change system gereetings
1 change primary greetings
the system will supply voice prompts to allow you to change system greetings, The superkey is the Blue key on the top left of the set
4 sys gereetings
1 pri greeting
if you are trying to change AA greetings follow the above just change the VM box number to the one associated with the Auto attendant alternativly you can configure the greeting from the System administration tool under the following ;
Sys Administration menu -> Voice Mail -> System audio files Update
IF you know the password for the mailbox then log into the voicemail by dialing the Stratagy access code, after Stratagy answers dial * , then your user ID mailbox number plus #, then your security code plus #. The User Main Menu plays, press 2 to change your greeting, the Select Greeting Menu plays, press the greeting number, the Record Menu plays, press 2 to record your greeting, Record greeting, as soon as you finish press #, the Record Greeting Menu plays, press 1 to review or 2 to re-record. Press 9 to save and return to the Select Greeting Menu and 9 again to return to the User Main Menu, hang up at this point.
-Dial into voicemail -Enter password to access system -Press button for Greetings or Administrative Options menu -Choose type of greeting -Press button to change it and record new greeting -Listen to new greeting and press button to confirm -Exit system
