SOURCE: jeep cherokee infinity amplifier
yes, you have a few options. Chances are, its your amp.
1st I would test the speakers - find the amp under the back seat, then test which wires go to the front speakers and use a AA battery to check if the speaker pops with those two wires and the battery.
If it does pop, its your amp needing replaced. You can switch out that infinity amp for an aftermarket one very easy. Just use a testlight, or voltmeter to test the wires, and switch them to a new 4-channel amp.
if you need the wiring diagram, let me know...and dont forget to rate me! or ask for more help!
SOURCE: Wiring diagram
Go to this link http://www.installdr.com/Harnesses/DCP-Wiring.pdf it has the wiring for the majority of chrysler radios. Just match up the plug and you will have your wiring colors. Good luck
-Andrew Hawkins
SOURCE: Chrysler Infinity power amp 36670 . Wet and not working
Odds are not good. Water damage to electronics is brutal, and 90% of the time it destroys the equipment beyond repair. But hey if your luck is better than mine, you may be in the lucky 10%.
