Erro codes is 52
The laser scanner speed is incorrect. X description: 1 = Scanner startup error 2 = Scanner rotation error
Probably Resolution : 1. Press GO.
The page containing the error will automatically be reprinted.
2. Turn the printer off and then on.
3. Re-seat cables to the laser/ scanner and engine controller.
4. Replace the laser/scanner.
I might as well tell you before hand, I'm Not sure if yours can be repaired but on older models I have repaired them by opening the laser/scanner assembly and removing the little circuit board with the motor and chrome spinning shaft. If you can remove the chrome piece from the motor you do so and then place a very tiny drop of synthetic oil down the shaft, install the chrome piece and spin a few time by hand and put everything back together. You can download the service manual by doing a google search. Look for instructions for removing the laser/scanner.
