Televison & Video Logo
A
Anonymous Posted on Apr 20, 2016
How does a ballast for a hitachi ultravision dlp tv look
L Pfaff
Level 3:
Top Expert:
  • Hitachi Master 11,573 Answers
  • Posted on Apr 20, 2016
L Pfaff
Hitachi Master
Level 3:
Top Expert:
Answers
11573
Questions
0
Helped
3583890
Points
181713
Anon, the bulb/lamp plugs into the ballast, The attached videos shows the ballast and location near the end of the video. Check the attached links. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
HITACHI how to replace your enclosure guide
Mitsubishi Toshiba Samsung DLP TV Bulb Won Turn On DIY Easy DLP Ballast...
hitachi ultravision dlp tv replacement ballast Google Search
5 Related Answers
Anonymous
  • 398 Answers
  • Posted on Jun 26, 2007
SOURCE: I Have a Hitachi Ultravision projetion TV Ned help to fix it.
This sounds like the solder joints on one of the convergence output IC's have cracked loose or the IC itself is defective and quitting when it warms up. The IC needs to be either resoldered or replaced.
Anonymous
  • 4402 Answers
  • Posted on Jan 07, 2008
SOURCE: hitachi ultravision
Check IC601, C603 for leakage, I601 and vertical pulse detector QN05
for poor convergence check RK42 for open circuit.
Anonymous
  • 121 Answers
  • Posted on Apr 13, 2008
SOURCE: PROJECTION TV HITACHI ULTRAVISION COLOR CONVERGENCE PROBLEM
it sounds like your blue convergence ic is getting weak you need to replace the ic's STK392-110 and you should replace both because when 1 is bad the other will go real soon. They are inexspensive at the sight I posted and you will also get free tech online support if you purchase them there.
http://servicemanuals.vstore.ca/
Anonymous
  • Posted on Apr 10, 2009
SOURCE: hitachi ultravision tv
tv comes on ,i hear but can not see
Anonymous
  • 261 Answers
  • Posted on Jul 09, 2009
SOURCE: Rear projection HD Hitachi Ultravision always has greenish tint
This is what you're going to do, Turn on the Tv and go to the service manual, if the green tint is still there, you have a defective dmd board, but if it's no there, then you have an issue with your video board
Were are both of the cooling fans located on my Hatichi Ultravision Dlp tv?
Some have cooling fan Located under the light Engine, Lamp Fan,Ballast Fan.on the Ballast Board.
Put new bulb in hitachi ultravision dlp tv and lamp light flashes and tv will not turn on. Have reinstalled old build and works fine. Is there any type of reset that needs to be set. New bulb no tv, old...
hey there it sounds like the problem is coming from your ballast board, the ballast board is the power source to the lamp. with time this part starts to wear out and get weak your old lamp is already burning out there for it does not need that much voltage to turn on but the new lamp has not been worn out or used there for it needs the ballast to be working at 100%
hope this solution helps
How heavy is a hitachi 52 inch dlp tv
The weight of the hitachi 52 inch TV is around 94.1 lbs 0r 42.6 Kg
Thanx
2answers
Hitachi ultravision projection that is turning off
Ur tv projection bulb,been a long time had not been replaced?If the the bulb been,replaced the ballast might be dead.
Picture on tv just went out and lamp light stays on
CK the Fans and Ballast Board for Parts Call Encompass Parts 1-800-638-3328 If the Lamp is OK its the Ballast Board
2answers
TV Exploded
Sounds like the DLP lamp failed. You can decipher the Hitachi flashing red light. That should help to be sure.
The DLP lamp replacement is fairly straightforward and can be done with minimal tools
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
