SOURCE: NEED A DIAGRAM OF HOW TO ROUTE A BELT ON A TROY
type in your model number to your search engine. find your model and the diagrams will be there.
hope this helps.
SOURCE: How to tighen the built on a Troy Built Pony 42in
You can't really tighten the belt on any of these mowers.
First make sure you have the right belt, if you measured the old one when it broke
then you were not using the size it was before it got all stretched out from use. Find a manual
or look around online for a source to tell you the size the belt should be new and get one.
Second there is a tensioner arm, spring, and pulley which take up the slack, this may
double as a clutch to put in slack when you depress the pedal. Make sure the pivot for the
arm, the spring, and the pulley/bearing are all in good shape.
Third there are belt guides which can also be worn and create slack, so check those and make sure
they are in good shape as well. I may not be the only one who ever put a belt on the wrong side of a guide.
Lastly make sure you have the belt on correctly, and nothing is bent, split, or warped.
SOURCE: can i get a diagram
without more information i can only give you a link.http://www.troybilt.com/webapp/wcs/stores/servlet/ARIPartFinderView?storeId=10001&catalogId=14102&langId=-1#Error
if this dose not help please contact me back with more info like model, make, year and I will do better.
Lowes or Menards sell troybuilt they may be able too hook you right up.
check the pedal adjustment the rod might have backed off
