The microwave is not heating up
Inside the machine is a fuse that is expressly for the magnetron tube. You may
or may not have special screws that hold the cover on, but usually they are the
tamper - proof kind, you Can buy the tool that removes them. The fuse will be a
small (1/4"x1 1/4") AGC type and will be white ceramic with a metal cap at each
end, this too, you can buy. After replacing the fuse, make sure that you put the
cover back on before testing the ' nuke '. The special tool ( if you have to buy
one) and the fuse will cost far less to purchase than a new unit. If the unit
still doesn't heat, then the problem will most definitely be in the mag circuit.
To replace the entire unit would be my best advice, to repair it costs more than
just money, you also have to hassle with the repair people and lose out on time
not having your 'nuke'
