You can install Linksys WRT1900ACS router in 2 different ways.
First Method: Install the router manually.
Second Method: Setting up WRT1900ACS router using the Smart Setup Wizard.
Linksys WRT1900ACS router setup Easy to follow steps
If you scroll to the network settings on your brother printer, you will see that you can navigate to the option where you select your wireless network and then input your password.
You could also select the WPS option on your printer and router to connect them without the use of your router password if you prefer.
