Sewing Machines Logo
Susan Posted on Apr 17, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Does my kenmore sewing machine Model number 5151 do zig zag stitch?
R.A. Ellis
Level 3:
  • Kenmore Master 12,731 Answers
  • Posted on Apr 17, 2016
R.A. Ellis
Kenmore Master
Level 3:
Answers
12731
Questions
Helped
2613433
Points
59176
I was able to find this photo on the internet. If your machine looks something like this
http://www.worthpoint.com/worthopedia/strong-vintage-kenmore-sewing-machine
Kenmore sewing machine in cabinet model 117 305 Collectors Weekly
Photo gallery Stitch in Time Must Liquidate EstateSales org
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=25&ved=0ahUKEwjXk5Gy3ZTMAhXhyIMKHaaSA_w4FBAWCEEwBA&url=http%3A%2F%2Fwww.searsarchives.com%2Fhistory%2Ffiles%2Fsewing_id.pdf&usg=AFQjCNEavJEwfhMVnix2pT0kwej_RSZ33A&cad=rja
then it most likely has zig-zag. There are a lot of dials and levers on this machine. Most straight stitch machines have only one or two. One dial/lever with numbers from 0-4 or 5 would be the stitch length. The other dial/lever with numbers from 0-4 or 5 would be stitch width, which would make a zig-zag stitch.
5 Related Answers
bargainbox
Hassy
  • 1388 Answers
  • Posted on Feb 24, 2008
SOURCE: singer sewing machine will not zig zag
Over time, and especially when not used, there is a likelihood of dust and old oil forming a sort of glue, or clag....
Remove the needle for safety, then, when you have the setting on Zig zag, gently push the needle arm to the opposite side of the zig stitch.......release the needle arm, and if it springs back quickly, it is fine, if it moves slowly, or almost not at all, then the clag needs removing with application of few drops of methylated spirit to start, at the sort of piston affair that shifts needle arm L & R .....move the needle arm back & forth until it frees up, a drop of oil to finish.........if almost seized, may require leaving overnight after using a penetrating lubricant if it is really resistant....I have had them on the bench for 3 days with manual manipulation a few times each day before they finally come good.
Denatured alcohol is fine, surgical spirit too, different countries have different names or products, essentially alcohol with few impurities that will evaporate quickly with little residue.
Hope this does work for you, tho' as I said, it may take a little time to penetrate depending on severity........the same applies to the reverse mechanism of many machines when they seize.
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Anonymous
  • Posted on Jul 17, 2008
SOURCE: Kenmore 1560 Sewing Machine
Be sure TOP control shows zig-zag. Flip top right bar from red to black or black to red on side of machine facing you. You can then change the widths by changing the numbers on that same circle control.
RickE1
Rick
  • 202 Answers
  • Posted on Dec 12, 2008
SOURCE: Zig Zag Not working on my Bernina 830.
Basically it is a matter of a stuck part. Flip open the top by prying up on the front or ends of the lid. You already noticed the hinges on the back. When you get it open, exercise the right hand lever on top (marked ZZ at bottom and 1-20 at top. If you look just to the right of this lever against the back wall you will see that it moves a little part back and forth into triangle shaped grooves. The part is not going completely into the grooves so drop some oil in there and exercise it a few more times, using your fingers if necessary to make the part move into the triangle grooves at the front and back. After a while it will loosen up where it should operate by itself smoothly . Hope this helps.
Anonymous
  • 323 Answers
  • Posted on Feb 16, 2009
SOURCE: can't tighten clutch on Kenmore zig zag sewing machine.
The clutch has fallen off the shaft. Remove the very small screw in the clutch release screw to remove the clutch release. Place the clutch(round thing with ears on it) back on the shaft with the center ears pointing towards the outside. Put the clutch release screw back on. Tighten it to make sure it works
properly. Put the small screw back in the clutch release screw and test it again. If it will not tighten or release properly, remove the clutch ,rotate it180 degrees and try it again.This should solve your problem.
sewman7
ken dourof
  • 980 Answers
  • Posted on May 14, 2009
SOURCE: Skipping stitches while zig-zagging
If you have put a new needle in then the chances are the machine has gone out of time, you can either take it in to the repair shop or you can contact me and I will attach timing instructions [email protected]
1975/76 Kenmore sewing machine will not zig say stitch
There is a zig zag gear in the top of the machine that breaks somertimes and thus prevents the machine from working correctly. Or it could be the machine hasnt been cleaned and lubricated properly.
Good Luck
2answers
Please how do I work a zig zag pattern on my manual operated singer sewing machine
Hello, Annelien -
Unless your manually operated sewing machine has switches to realign your sewing machine needle to make zig zag stitching, as is demonstrated in this YouTube video (starting at around 6:30 minutes in the video):
https://www.fearlessmakers.com/manual-sewing-machine-works/
you cannot. Note: The machine in the video is a Necchi brand sewing machine.
Without knowing the model number of your manually operated Singer sewing machine, I cannot try to find operating instructions for it to determine if your machine has zig zag stitching potential.
Best wishes.
Does my kenmore sewing machine model # 158.17540 Do zig zag stitch
Here's a manual you can order for your machine:
Kenmore 158 instruction manuals 3
This sewing machine vendor sells a needle plate for your Kenmore. Because the needle hole in the plate is wide, it most likely has zig-zag capability. A straight stitch machine would not need a wide needle hole if it sews only forward & backward.
My Kenmore 19233 refuses to zig zag stitch past 2mm wide. At 2mm it is a reliable stitch, moving toward 7mm it is a straight stitch with one or two zig zag blips.
Do you have it on zig zag or maybe it is in one of the hem stitches. Make sure you have not selected a special stitch. Sometimes with a small width setting it looks like no zig zag, then when you increase the length you see it is not.
Kenmore ultra stitch 6 Model 13402
If the machine is not zig zagging when you select zig zag it will mean the selector finger needs adjusting which is a shop job
Kenmore 385.12490
Check the position of the Button Hole Stitch adjuster that is directly under the stitch length control. It looks like a flat head screw and should be straight up and down for normal sewing.
Trouble sewing lycra fabric using a zig zag stitch
You have the machine set for blind hem stitching. Change the stitch selector to stretch stitch, which is a single, in line stitching zig zag stitch.
Cheers,
Embroidery Services
San Diego, CA
3helpful
How do I do a stretch stitch?
The bes way to hem a t-shirt on a household machine is to use a double needle, straight stitch. You will see two straight stitches on top and zig zag on the back. Just make sure the zig zag catched the top of the hem.
Top Kenmore Sewing Machines Experts
ZJ Limited
ZJ Limited
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
