Check the leftside manual transport bypass lever has not somehow engaged. Compare it to the right side.
The two transaxles are driven by the same belt so extremely unlikely it's a belt problem.
Look for any signs of fluid leaking from the left transaxle shaft seal. If the seal has been leaking then it may be low on fluid. The transaxles are considered maintenance free so there are no instructions from Husqvarna for adding fluid but it can be done. However, if the shaft seal is leaking it will need replaced.
See operators manual regarding bypass levers (rods).
still plenty of parts available,the dimensions arent included,but you can find cheaper belts,just dont use an automotive belt,they wont last through 1 mowing,get the ones with kevlar,they r more expensive but,will last for a long time, Husqvarna Drive Belt Part 539117245
If the unit stopped moving at once. I suggest checking the belt. It is very unlikely both Hydro-Gear units would fail at the same time. check under the mower, and check on top of the transmissions, you should see the drive belt running between both transmissions and the engine.
Not sure the problem, there are no gears on the drive system. This uses Hydro drive wheel units. If the belt is on and in good shape, check the lever linkage.
