HTC Desire Cell Phone Logo
A
Anonymous Posted on Apr 16, 2016
HTCDESIRE 820U,BUT THE MOBILE NETWORK IS SHOWING 2G ONLY,I CHANGE MY PHONE CONFIGURATION(APN),BUT 2G IS STAY NOW,HOW I SOLVE THE PROBLEM FOR BECOMING 3G?(THE PHONE IS BEAR FROM UAE)
SARWAR,EMAIL:[email protected],M.NO:01675437911,BANGLADESH
4 Related Answers
Anonymous
  • 7 Answers
  • Posted on Mar 12, 2009
SOURCE: hi, i am Vikash K Sharma from Gorakhpur in India,
Go to nearest service center and change the touch screen....
Anonymous
  • 6 Answers
  • Posted on Jul 30, 2009
SOURCE: Forgot pattern and email cant get...
are you haveing problems with your 1 phone . if you are then turn your phone off press the house &end button together the a triangle will pop up and you have to press it and it will work if not then instead of pressing the end buttton&the house preaa alt &the house button hope i helped
Anonymous
  • Posted on Sep 02, 2010
SOURCE: hi, i had my G1
Problem is that i live in Israel, no T-Mobile here, i purchased the phone in ebay
Anonymous
  • 502 Answers
  • Posted on Apr 14, 2011
SOURCE: MY HTC P3400i IS DEAD. Just doesn't turn on.
There may be a physical issue with your logic board. You can get the part at HTC p3400i Repair and there is a guide that shows you how to put in the part at HTC Repair Guide.
Apn settings for Safety Net/Lifeline on AT&T Samsung J7
these are apparently the settings
https://www.fixya.com/support/t26922303-apn_settings_safetynet_wireless_lifeline
APN & data settings
  1. From any Home screen, tap Apps.
  2. Tap Settings > More > Cellular networks.
  3. Tap Access Point Names.
  4. If available, tap the T-Mobile US APN.
    • If not available, tap the New APN icon.
    • To reset your APN settings, tap the Menu icon with three dots, then tap Reset to default.
  5. Verify and update the following settings for the Data APN:
    • Name: T-Mobile US
    • APN: fast.t-mobile.com
    • Proxy: <Not set>
    • Port: <Not set>
    • Username: <Not set>
    • Password: <Not set>
    • Server: <Not set>
    • MMSC: http://mms.msg.eng.t-mobile.com/mms/wapenc
    • MMS proxy: <Not set>
    • MMS port: <Not set>
    • MMS protocol: WAP 2.0
    • MCC: 310
    • MNC: 260
    • Authentication type:<Not set>
    • APN type: default,supl,mms
    • APN protocol: IPv6
    • APN roaming protocol: IPv4
    • Enable/disable APN: <greyed out unless there are multiple APN's>
    • Bearer: Unspecified
    • MVNO type: None
    • MVNO value: <Not set>
  6. Tap the Menu icon with three dots, then tap Save.
  7. Tap the desired APN profile you want to use. The bullet point fills with color next to the APN profile.
Manual network selection
The device detects and registers on wireless networks inside T-Mobile's calling area, but roaming networks are usually restricted to T-Mobile SIM cards. You can manually select a network only in areas where T-Mobile does not own GSM spectrum.
  3. Tap Network operators.
  4. Wait while the device populates a list of available networks.
  5. Tap the desired network you wish to register on.
Switch 2G / 4G
  3. Tap Preferred network types.
  4. Choose from the following options:
    • LTE/WCDMA/GSM (Auto mode)
    • WCDMA/GSM
    • GSM only
Turn on / off airplane mode
Airplane mode turns off wireless connections. This allows app and menu use, but prevents voice or Internet use.
  1. From any screen, swipe down from the top of the screen.
  2. Tap the down icon (v), the tap Airplane to turn on or off.
Turn on / off data roaming
  3. Tap to turn Data Roaming on or off.
Turn on / off mobile data
  1. From any Home screen, tap Apps > Settings > Data usage.
  2. Tap to turn Cellular data on or off.
From - https://support.t-mobile.com/docs/DOC-28547
this is the instructions for samsung on how to change settings
https://www.t-mobile.com/support/devices/android/samsung-galaxy-j7/network-apn-and-volte-samsung-galaxy-j7#steps1
T-mobile apn on ZTE Z836BL What are the APN settings
Access Point Name
An Access Point Name (APN) is the name of a gateway between a GSM, GPRS, 3G or 4G mobile network and another computer network, frequently the public Internet. A mobile device making a data connection must be configured with an APN to present to the carrier.
CALL TO T MOBILE CUSTOMER SERV. THEM GONA BRING YOU THE APN INFO
Life wireless apn settings for at&t huawei ascend xt2 H1711
APN & data settings
    • Name: T-Mobile US
    • Proxy: <Not set>
    • Port: <Not set>
    • Server: <Not set>
    • MCC: 310
    • MNC: 260
    • MVNO type: None
Switch 2G / 4G
    • WCDMA/GSM
    • GSM only
  1. From any Home screen, tap Apps > Settings >Data usage.
From - https://support.t-mobile.com/docs/DOC-28547 Network APN Kyocera DuraForce XD
Good Afternoon..... I cant receive or send pictures what is the APN code for SVP G13 watch phone
An Access Point Name (APN) is the name of a gateway between a GPRS, 3G or 4G mobile network and another computer network, frequently the public Internet. A mobile device making a data connection must be configured with an APN to present to the carrier.
For AT&T
Programming non AT devices with the correct APN and MMS data settings AT...
For Tmobile.
Mobile apn settings Step by Step Configuration
I can't make calls nor receive
Check to make sure phone is registering in network. Check a network is selected. Try the following.
APN & data settings To set the Access Point Name (APN) and turn on data settings, follow these steps:
  1. From any Home screen, tap the Menu key.
  2. Tap Settings.
  3. Tap the Connections tab.
  4. Tap More networks.
  5. Tap Mobile networks.
  6. Tap Access Point Names.
  7. If available, tap the T-Mobile US APN (the bullet point fills with green). If not available, tap the Menu key, and then tap New APN.
    Note: To reset your APN settings, tap the Menu key and then tap Reset to default.
  8. Verify and update the following settings for the Data APN:
    • Name: T-Mobile US LTE
    • Proxy: <Not set>
    • Port: <Not set>
    • Server: <Not set>
    • MCC: 310
    • MNC: 260
    • Authentication type: <Not set>
    • APN type: <Not set> OR Internet+MMS
    • APN protocol: IPv4/IPv6
  9. Tap the Menu key.
  10. Tap Save.
  11. Tap the desired APN profile you want to use. The bullet point fills with green next to the APN profile.
Manual network selection To manually select the wireless network the device connects to, follow these steps:
  2. Tap Settings.
  6. Tap Network operators.
  7. Tap Search now.
Switch 2G / 4G To change the band between 2G and 4G, follow these steps:
  2. Tap Settings.
  6. Tap Network mode.
  7. Tap one of the following desired band settings:
    • GSM / WCDMA (auto connect)
    • GSM only (2G only setting)
    • WCDMA only
Turn on / off Airplane mode Airplane mode turns off wireless connections. This allows you to use apps and menus, but not make calls or use the internet.
To turn on or turn off airplane mode, follow these steps:
  2. Tap Settings.
  5. To turn on, tap Airplane mode to select the check box. Tap OK.
  6. To turn off, tap Airplane mode to clear the check box. Tap OK.
Jul 06, 2014 • Cell Phones
How to open mms in android samsung mobile the mms which i have received
Hello Sanju
I assume there might be MMS settings which you need to get from your service provider.
You can try these steps
Click on Settings ' Wireless and Network ' Mobile Networks - and ensure "Use packet data" is on.
Also.. in the same menu window - enter Access Point Names and ensure that you have your network provider's MMS APN configuration in there. Some network providers can send the configuration to you by their website or a phone code.
Some network providers might request you need to have at least a WAP or Internet APN (Access Point Name) configuration before MMS gets delivered to your mobile phone... if the above still doesn't help you download MMS, install a WAP or Internet APN configuration through your network provider - (by: Naith_KK)
Hope this should do the trick.
Feb 18, 2014 • Cell Phones
1helpful
I have a 5 month old HTC Wildfire. I don't have access to WiFi and most often use Vodafone Mobile Connect to connect to the Internet. Suddenly, since the day before yesterday, whenever I'm trying...
Seems like your phone is functioning correctly.
You have disabled wi-fi so it is asking whether you wish to use Phone Data Connection instead. (Standard Practice when trying to access data services)
What you need to do is un-tick the option in options Use only 2g networks. (3g is the mobile data service) That should then allow you to access Mobile Data. (3g)
Also enable data enabled
Jun 17, 2011 • Cell Phones
5helpful
Hi. Please help i cant use Globe network as my internet for my HTC Wildfre. Please help the correct settings of mobile network. thanks
1. Go to Settings->Wireless & Networks->Mobile Networks->Access Point Names
2. Click Menu->New APN and follow the setting below (leave settings as is for those not mentioned)
  • Name: Globe Internet
  • APN: http.globe.com.ph
  • APN type: default
3. After saving the settings above, select the newly created APN (green radio button appears).
Your phone is now configured to use the newly created APN.
2helpful
Can't connect to internet due to no configuration settings available from Globe network. Present location - Philippines. Fon was from USA, just unlocked it here in the Philippines.
Your Motorola CLIQ MB 200 has an Android OS. Here's how to configure the internet on your phone:
Go to 'Menu'. Choose 'Settings'. Choose Wireless & networks Select Mobile networks. Go to Access Point Names. Press the Menu button. Tap New APN.
Supply the following settings for Globe Telecom:
Name: GLOBE (or anything you want) APN: http.globe.com.ph LEAVE THE REST OF THE FIELDS AS-IS
I hope this would solve your internet connection problem.
3helpful
Network Connection error
This is a tutorial on how to add APN settings to HTC phones for your network providers. Example phone used is a HTC Hero but process is same for all HTC models.
Android APN and Data Settings Change for HTC Phones
  1. Go to settings -> wireless controls
  2. Go to Mobile Networks -> Access Point Names
  3. Click Menu and select New APN
  4. All you need to add for most networks is just the APN setting which can be obtained from your simcards network provider
  5. Press Menu and Save
  6. You are ready and have configured data connection settings.
Enjoy your HTC phones unlocked for Voice and Data for any network. see video below
Top HTC Cell Phones Experts
NOEL
NOEL
john h
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
