It is password. Thats the password
This link will help you find more information about guest network.
Linksys guest network access
SOURCE: password
Since you forgto the password the best way to make this router work fine is to reset it and reconfigure it back, To reset it just press and hold the reset button for 15 seconds while the power is ON, then if you still have the setup CD just run and that should take care of everyting, but if you don't have the setup CD you can manually configure it by accessing the router setup page if you're not familiar on how to do that better call LInksys tech support and let one of their tech walk you through with that process they are open 24/7 this is the number 800-3267114..........
Hope that helps............
SOURCE: how do i reconnect linksys
Oh man your going to have to help me out a little on this one. Do you mean you had to unhook it and connect directly to the modem and now you want to hook the router back up? If thats the case Unplug all the devices (Pc's modem and router) connect an Ethernet cable from the ethernet port on the back of the modem (not the linksys) to the internet ethernet port on the linksys (usually set a little apart from the rest) then connect all the computers to the routers ethernet ports (usually labeled 1-4) then turn on power to the devices starting with the modem, wait for it to completely boot up all the lights like they're supossed to look. Then turn on the router and wait for that to finish booting up then all of the computers. If you have wireless devices that will take a little more help.
SOURCE: im trying to set up internet for my ipod touch and
Yes, you really need a password for that (either WEP or WPA). You can ask for the password to the one who configured the router. They placed a password for security reasons. In order not all people can access net, only those who knew the password.
SOURCE: I need a network name and password for my linksys router WRT120N for internet access thru my blu ray
Try the following Username: admin Password: admin Username: admin Password: leave it (blank)
