Where may I buy a battery KLC I 7000 my area code is 01851 . My camera will
Not take
a charge, cannot find any store that have any, but they sell Kodak cameras.
Re: Where may I buy a battery KLC I 7000 my area code is...
Anon, Walmart if in stock, links below will allow you to order battery.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
It will not help to try to charge those batteries. No amount of charging will bring them back You will need to buy 2 U1 batteries if your chair is a smaller Jazzy or Jet. The heavy duty chairs take a bigger size battery Hope this helps you Check if there is a battery distributor or store in your area they will be cheaper than going to a provider that sells chairs
Hello,There is no way to charge the KLC-5001 battery with a usb cord,It requires a voltage supplied by the charger or the dock.There are after-market chargers available on E-BAY. They do not cost very much and some even come with new battery.Hope this helps. Best Regards, Russell
remove the battery holder. remove the screws from the metal plate. gently raise the plate and remove the battery. remember the different size screw lengths. the battery can be bought at any drug store or camera store.
it may take awhile for systems to turn on.
You can find them on ebay, and most of the electronic stores (Best Buy, Ckt City, etc.) sell a charger that will charge many different batteries. Just look for EN-EL3, which is the battery in the D70.
First thing is to be sure battery and its connection to camera terminals is good. Be sure the battery charges normally when plugged into its charger. Charger light should be green when charging, then go out when done.
Next is to clean the battery contacts with a clean pencil erasure to remove any potential contamination built up. Now, try to measure the battery charge across its pos (+) and neg (-) terminals. This means either finding someone who can do this for you if you don't have a Volt Meter, or buying one at RadioShack or any Auto Parts store. The simple ones are cheap and this is all you need. A fully charged battery should measure about 4V DC.
If the charger and battery are good, then with the battery out of the camera, cycle the camera power switch on/off several times to try to clean its contacts. Now install the battery and move the power switch to on and hold for a good 5 seconds. Repeat this a few times.
If no response, then camera is defective. Sell it on ebay auction to a repairman who will buy it to fix and resale. Now buy youself a used, refurb w/warranty, or new on on ebay. Prices are very good because many are for sale(this is a very popular camera and millions were sold) and the TZ3 has been replaced with the newer TZ5.
It is easy to post your camera on ebay. Just search for a TZ3 for sale and on its Ad Page, you will find a link that says "Sell one like this". This will set you up with a TZ3 Ad Template w/default picture and Specs, and you just follow the prompts for your Headline/price/shipping/ etc.
rtjohnson1,
the minolta 7000 was the first auto focus slr. you can still buy a good working 7000 on e-bay for around $40.00 to $50.00, or take a 7000 lens to a camera store and try it on a newer model.
HFMagna,
there are no new parts available for the 7000, but if you go to a camera repair shop they may sell you a used one, or offer to install it for you at a reasonable price.
