Dishwashers Logo
K
Kathy Strabel Posted on Apr 14, 2016
Model JDB1105. Why does it make a popping sound when pump begins?
  • Kathy Strabel
    Kathy Strabel Apr 15, 2016
    Popping sound solved. It was a small piece of plastic lodged near the food chopper. The plastic broke off of one of the clips inside the dishwasher; My husband took the pump assembly apart from the lower spray arm on down to the inner workings and extracted a piece of dark gray plastic. The popping noise was the plastic piece being swirled around inside the drain area where the chopper is located. No need to remove dishwasher from the cabinet, just start removing the pieces and lay them out in the order you remove them for easier re-assembly. Good luck!
I need instructions on how to fix belt on the Whirlpool,. Ultimate Care 2. model # LSQ9659PW2
you have a motor coupling in this no belts,most likely you have a bad trans.tilt the machine back or take panel off,check the motor coupling but i think you have a bad trans. run your hand behind the motor on the bottom of trans. and see if any oil is there,if so bad tranny ,one more thing you can pop off the two clips that hold the pump on,remove the pump from the motor shaft,stick a jumper wire into the lid switch harness,stick one end into each outside connector of the lid switch and spin it,something could be in the pump.watch video to take off panel
http://www.youtube.com/watch?v=DwV71h86Gxw
How do you prime the siena?
Schaerer Siena machines can become airlocked from time to time leaving the pump running yet sounding rough. Easiest way of remedying this is by running the hot water (either by pressing the jug button or turning the hot water knob on the side depending on which model you've got) option through the silver wand. Once you get a strong water flow through this then the machine pump has been primed and you can then begin making coffee as normal. You'll notice the sound the pump makes will change as the water comes through.
Alero Stalling and Problems starting.
Check your fuel pressure sounds like to me the fuel pump is weak or worn out.
Washer will not begin spin cycle
Hello,It needs a drive coupler for the motor/transmission.
Unplug machine. Just lean the machine back, pop the two clips on the pump and put it to the side. Take the two screws out of the motor clips (usually 1/4 inch), and pop those clips off. Motor will come off. You will see the 3 fingered white piece on the motor shaft and one on the transmission shaft. There is a rubber coupler that connects the two. Replace which ever white plastic piece is broken, or the rubber piece if that is it. Make sure not to bang the white plastic piece too far onto the shaft. The shaft should go flush with the white plastic part facing you. Put motor and pump back together and plug in motor.
Thanks
1helpful
My GE Profile dishwasher has a clicking noise in the motor. It sounds like a BB is rotating in it when the motor kicks in. What can I do?
Sounds like something is caught in the drain pump (if it occurs when you begin the cycle) or wash pump (if 3 minutes or so after the cycle begins) You can check the wash pump by removing the screen in the back.
St. Paul Appliance Rescue
My Maytag Wide by Side refrigerator has been making loud popping noises and now the freezer is not cooling properly. What is causing this?
Does not sound good. We need to find ou where the popping noise came from first. Not cooling is because it sounds like the popping noise is from that area but for sure that area. It could be a failed control board and shorted out the compressor relay.would like to go and do this yourself of have a technician like myself lead you through this? I'm going to get the service manual and if you would like a copy I will get it for you, Thanks and let me know soon, Sea Breeze
spotted cow make sure the model number above you post is correct before we begin
My tv made a popping sound then the color started to mix then went black and is making a humming soun. it sounds like a jammed cd in a player
i would need the model number of your set to even begin to help you with a possible solution. please respond to this same post
2answers
Bosch sgs6302gb
the problem is the circulation motor needs to be loosen up take a 5'16 driver open the filter on the bottom and loosen it at froom thr small hole on the left.
Top Jenn-Air Dishwashers Experts
Mike Cairns
Mike Cairns
Renee Knafel-Bullock
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
