Question about Minn Kota Boating
WHO STOCKS A 2991251 CABLE FOR A MINN KOTA - Minn Kota Boating
    Top Expert:
  • 11,573 Answers
Sherry, I think there may be a new Minn Kota part # . Check the attached links. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Minn Kota Power Drive Non Auto Pilot Coil Cord Assembly 2991283
Minn Kota Trolling Motor Part COIL CORD STRN RLF PD48 54 2991283
http://minnkota.com.au/wp-content/uploads/2014/07/55-PowerDrive.pdf
Can get replacement parts for my Minn Kota trolling motor FAQs
Posted on Apr 13, 2016
Anonymous
SOURCE:
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    My Johnson Escape boat w/ Minn Kota engine stopped running
    I've had the same problem. It steams from the control panel. I took and ran a seprate ground wire directly to the motor. This is simple to do and takes 15 minutes. Starting in the battery compartment feed cable into the split-loom and continue feeding until reaching the control panel. Pull an extra 5 foot of cable and open dry hatch in rear by motor feed cable around and out to motor connections., Good time to replace rotary switch and circuit breaker. These also are trouble-some parts.
    Aug 01, 2010 | Minn Kota Boating
    Lookinf for a manual for a minn kota model 55d
    call 800 number for minn kota on your motor. they are very helpful and will fax or emial you a manual for the motor. good luck.
    May 28, 2010 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    Minn kota will turn on and off with remote, but will only turn 1" to each side.
    take off the top cover on the head of the motor and see if there are any restrictions to the movement of the cable. it may be the cable itself is rusted internally and may need replacement. call min kota on the 800 number on the motor for prices for any patrs you may need.
    May 28, 2010 | Minn Kota Riptide Sp Saltwater 70 Bow...
    Broken plastic on minn kota steering cable
    Hi!
    Here's a schematic:
    Edge 40
    My guess is you need key# 80 (part# 2232360 cable drum pulley)
    Good luck in your repair!
    Mike
    Sep 19, 2009 | Minn Kota Edge 40 Freshwater Bow Mount...
    I need Minn Kota Power Drive operators Manual
    I'm installing a Minn Kota Power Drive 70# on my Crestliner Fishhawk. I understand the 24 volt system. however the boat has 2 black, an orange and a red wire running to the batteries. I know black to neg. but where do the orange and red wires go.
    Jun 09, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    I HAVE A MINN KOTA DECKHAND 35 THAT WONT WIND UP. IS THERE A GEAR I CAN REPLACE?
    Solution- Take the cover off the Deckhand 35 by Minn Kota. Inside is a motor drive. Remove the cover plate held in place with 4 screws. inside are nylon gears, most likely broken. The gears can be replaced with a Minn-Kota Deckhand Gear Repair Kit.
    I found mine on the web at Northland Marine.com it's about $24.00 for the kit, plus shipping.
    Good Luck!
    Jun 09, 2009 | Boating
    I cant adjust foot tension on minn kota edge
    Hi!
    Flip the foot pedal over and tighten the set screw where the cable enters, this should help out.
    Here's a schematic:
    Edga 40
    Best of luck!
    Mike
    Jun 06, 2009 | Minn Kota Edge 40 Freshwater Bow Mount...
    Boating Logo
    311 people viewed this question
    Top Minn Kota Boating Experts
    Colin Stickland
    Colin Stickland
    Andrew Taylor
    Andrew Taylor
    Mike
    Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
