How do i change the driver side front hub assembly
The vehicle will need to raised on the left (drivers) side and supported. Remove the tire, then the brake caliper assy. Remove the rotor, then remove the axle nut located in the center of the hub assy. Remove the hub/bearing retaining bolts, and then the hub assy. Some times it is corroded into the steering knuckle assy. and will not seem to come out. If this happens, install the axle nut, and wearing safety glasses, pound onto the hub flange from the inside to the outside, until it comes out of the knuckle assy. Then remove the hub assy. Clean the knuckle hole where the bearing with 120 grit sand paper, so the hub/bearing assy will go into the knuckle without damage. Torque the axle nut to specs. Clean the inside of the rotor, where the hub meets it, so it sits flat against the new hub. Install the rotor, caliper assy. Install the wheel and torque the lug nuts to 100 ft pounds. Road test about 5 miles and recheck the lug nuts.
